New 820 Sterling owner
- Captain Sensible
- Joined: Tue Jan 13, 2015 10:51 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi everyone,
I've long admired Rover Sterlings from afar. I've wanted one since I was about 12, and last weekend I made that dream a reality and put down a deposit on a 1998 Rover 820 Sterling auto. This Saturday I go up and collect it - an understatement to say I'm over excited.
It's not you're average car choice for a 21 year old, partly a reason why I love it so much.
The car itself isn't in bad order overall, but there's a list of issues which will need fixing sooner rather than later:
The driver's door won't open. The door handle broke just before I was about to make an offer!
The head offside headlight is making a very odd sound on some settings. I'm guessing it's a worn adjuster gear, but we will see.
The boot leaks and the spare wheel well will need cleaning up to get rid of surface rust, and the leak will need to be traced and fixed ASAP.
Another problem is the rear arches are just starting to go crispy on their inner lips. Not the end of the world as it is, but again it needs fixing as a matter of urgency.
Not so urgent is the radio which only plays White Noise FM, and a previous owner has clobbered the front wing and the middle box is also held on by gum and hope.
I'm probably making the car sound like a dog, when it really isn't - I just want to catch it before it ends up as such. Good points are the T-Series pulls great, the autobox is smooth and the aircon works (I was stunned). I paid £680 for it, probably a little overbook considering it's faults, but it's in the colour I want (Oxford Blue) and has the right colour leather (cream). I also got a hideous vision of it being used as a cheap family hack, filled with rubbish with finger prints on the windows before being scrapped a year later. No way! It needs saving and bringing around again! It's done a genuine 68k.
It was sold as spares or repairs and I'm thinking of it as a winter project.
Some pictures to be getting on with...Brum reg too. Rover Group were the first registered keepers. It may look a bit OTT for a first car, but because of what I do for work I'm used to driving big cars. I won't mention how much insurance is
Pictures flatter it, the paint is as rough as whatnot. That comes later, after I've sorted the niggles and serviced her.
Thanks,
Sam
Thanks,
Sam
- TDHFastback
- Moderator
Re: New 820 Sterling owner
That is a lovely colour combination the blue and cream.
Welcome aboard the 800 flagship.
I'm sure any problems you have will but quickly sorted by the knowledge on this forum. They are a fine bunch.
Be careful though you may get hooked and start looking for others. 800s have a waay of getting under your skin. You have been warned
Kate
Kate
- Captain Sensible
Thanks Kate.
I love the colour combo, it's just what I've been looking for. It's great to have help and support - any is greatly appreciated.
I can really see how they're addictive. I've already found myself looking at base spec cars for sale cheaply, and thinking to myself, "Is it cruel to use the Sterling as a daily? Will it get lonely and want a friend?"
Welcome to the forum, we should be able to help you.
Lovely car that deserves to be rescued!
Welcome.
Welcome.
- Captain Sensible
Thanks for the warm welcome!
That looks alright
Welcome to the forum and the Rover 800 habit.
To get you started and while the weather is rotten, the leak into the boot is probably from the rear light cluster, this can be from either side or both, just lift out the rear mat and check around the bottom of the rear quarter trim panels for damp. The foam seal which is no longer available to buy becomes depressed and allows the water in, a good silicon bead should fix it or a nip up on the 8mm nuts. Not too tight or will break. Moisture trap's from pounland help in removing moisture out of the air and any damp smells.
- Captain Sensible
Thanks Rovercoup. I'm crossing my fingers that the boot will just need a new seal...chances are I won't be that lucky. Oh, a moisture trap is on the list for sure!
