Hi everybody, I've just bought an 800
- Location: Oxford [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi, my name is Ian. I've been reading this site for years on and off. Today I bought a mk1 827 Sterling, so I thought now I must register.
Re: Hi everybody, I've just bought an 800
Welcome Ian, look forward to hearing about your new toy.
Hi, looking forward to seeing a few pictures of the new car. Welcome to the forum.
- TDHFastback
- Moderator
Welcome aboard the Flagship Ian.
Look forward to seeing some pictures
Kate
Kate
i have a few pics, but I'm not great with computers, so putting them on here using my iPhone is a little beyond me at present. I'll have to do a little reading. Thanks for the welcome.
Actually the car needs a new head gasket, which I'm not to worried about as I managed to get a second 827 included in the price.
- BlueRover
Welcome Ian.
It would be a good idea to change the water pump too (as a precaution) as it's supposed to be much easier when the heads are off.
I've not done one myself as all the 800s I've owned have been 4-pots.
I can't work out how to send pics here from my IPhone.
The cars eventual value is not going to be an issue to me as now I've found the one I've always wanted, I will be keeping it so here's my choice. Do I have the original engine repaired so the car maintains its original numbers etc, this engine has done 50,000 miles?
Or,
Do I undertake an engine swap from the other 827 that I have also acquired as a spares car? This engine has covered 1000,000 + miles.
If I have the original engine rebuilt, I could have it repainted and cleaned right up, but if I do a swap, then there seems little point, as there's no reason to have it pulled apart.
In whichever course of action I take, I won't be doing the work as I am registered blind, so will be looking for a recommendation either for a good engine restorer or garage to have the work done.
I don't have bags of money, but as my intention is to keep the car, I want to lavish love on it.
Or,
Hi Ian, welcome to the site.
IMO I would use the 'new' engine if you know it's running well at present? The original engine could have more wrong with it than just HGF and could easily turn into a full rebuild.
Pulling the engine is really not that difficult for a garage.
In some ways it would be easier for them as you should really be looking at changing the cambelt and water pump as a minimum. Possibly even further jobs.
Last time I did it I had a leaky sump which needed welding and exhaust manifolds which required re-studding.
Thank you so much for the advice. I think I will do the engine swap and then send the other engine away to be completely rebuild. As I intend to keep the car, maybe at a future point in time a spare engine would be usable in some way, as I know what I'm like. I've owned a few classics over the years, but just one Rover. I don't see that lasting now that the dormant bug has finally bitten.
I am very happy with the car. Hopefully I can arrange for it to be delivered by Thursday.
- vito
Lovely car, looks a bargain
Thank you Gaz. Both for posting the picture for me and for your comments.
I now have to sell my mk1 216s and 2 x Nissan bluebirds.
I agree, my issue was local garages knew the potential hassle and most wouldn't touch them or quoted a silly price to not get the job.mrpcpc wrote:Chris, As far as the exhaust studs are concerned I have had a few done my self. I have had then drilled, then helicoiled to a take a standard 10mm stud. This has save dme so much agro later on. I also very rarely bothered refitting the heat shields. Although some may frown upon this, they don't seem to have had any detremental effect anywhere nearby.
If it were an 820 turbo I wouldnt dream of leaving the shield off
So anytime I had an engine I out I had them redone to save hassle like you. Cost me £10 a pair with the manifolds off the car.
My point really was its a good idea to get them done while its out. Same for the thermostat and probably other jobs?
I moved from Cardiff to Oxford in 2013z. I had a house with plenty of parking space. Now I live in a flat with one parking space and I own 5 cars. My neighbours question my sanity as I'm registered Blind so can't even drive my own cars on the road. Lol.
Regarding space, currently my cars have a bigger footprint on this earth than my one bedroom flat. Lol
When the housing association ask why the wall and window are missing, I'll just answer "well I am blind you know". Lol
