New Mk1 Vitesse owner and forum member
- Joined: Tue May 23, 2017 9:57 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Evening All
Just a brief post to announce myself, I am the very happy owner from Braintree in Essex of a white manual Mk1 827 Vitesse in apparently mint condition. I previously owned a Mk 1 Vitesse many years ago but I got rid of it once the auto box wouldn't get out of second (which spoils the 827 fun when you are keen to make progress), aside from that issue I think I was hooked on Rover from that car onwards. I must of had 6 or 7 75's including two V8's, for some unknown reason I sold my last V8 but I am keen to put that right and add it to what I hope will soon be my new Rover collection.
Looking forward to keeping this one preserved and occasionally used with the help of you clever lot!
- vito
- Location: Lincolnshire & Enix, España [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: New Mk1 Vitesse owner and forum member
Welcome Chris, you should post some piccies.
- SJG
Welcome Chris, apologies for the delay in you gaining access to the forum.
- Nuts4my827
Welcome aboard
- Location: Hampshire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Welcome aboard.
10 Rover 800's now and counting.
2x Mk1 827 Vitesse Fastbacks
3x 825 Coupe
Mk1 827 Sterling Saloon
825 Sterling Saloon
825 Sterling Fastback
820 Vitesse Coupe
820 O Series Mk1 Fastback.
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
Welcome aboard the flagship Chris! Think i know the car you've got, nice one if so!
- Joined: Thu Feb 12, 2015 9:00 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Excellent excellent.I was the last owner before you bought it at the auction.Glad it isn't disappearing of the radar
I so much wanted it to go to a club member or forum member.
One job that might need looking at is possibly the thermostat.The temp is always fairly low so it could have the wrong one in it.
Ask for advice,these guys really know there stuff
If the 'stat is weak the torque converter won't go into lock up mode - the gauges usually sit at the "half past 8/twenty to 9" position.
Standard 'stat is a cool 78C - a "dealer upgrade" when they were new (or standard fit in the rest of the world, why did we get a cool 'stat? ) is the 82C 'stat from an 89-95 216/416 or Civic/Concerto. It's a straight fit, improves warm up, economy, power, emissions and gives more margin for error on the torque converter lock-up. Make sure you order the "kit" version as it will come with a new rubber seal that fits round the edge of the 'stat. The old ones usually crumble when they're removed!
- rovercoup
It's a manual Davescoobyh123 wrote:If the 'stat is weak the torque converter won't go into lock up mode - the gauges usually sit at the "half past 8/twenty to 9" position.
The torque converter bits won't apply then Steve!rovercoup wrote:It's a manual Davescoobyh123 wrote:If the 'stat is weak the torque converter won't go into lock up mode - the gauges usually sit at the "half past 8/twenty to 9" position.
Maybe i'm thinking of a different car or forgot it was manual.
As I said you guys know your stuff.Thanks for the advice you gave me during my ownership.Now it's time to look after the new owner of this beautiful vitesse
