Mk2 2 litre air con compressor
Post by SJG » Sun May 28, 2017 5:40 pm
Does anyone have a good working unit please? As the title says it's for a mk2 2 litre turbo engine, but I don't think it matters whether it's from a turbo or nasp model. Many thanks.
Re: Mk2 2 litre air con compressor
Post by scoobyh123 » Sun May 28, 2017 6:11 pm
Are you sure it's the compressor Simon?
If so, the 2 litre compressors are fairly interchangeable, there's 2 or 3 different ones and one of them is the same as the early Mk2 2.7 in which case i can probably help. I have one that i bought a few years back, the pipes were cut and then sealed up with duct tape keeping the oil in the compressor. I can dig it out and confirm the part number and if you can find the part number on yours i can cross reference them to make sure it's the same unit. :wink: :D
Post by SJG » Sun May 28, 2017 6:18 pm
Thanks Dave, there is a bit of a story. I will let you know when I have a few moments spare!
Post by scoobyh123 » Sun May 28, 2017 8:32 pm
Oooo-errrr!!! :shock: When people say "a bit of a story" that can often be a scary story!
Weather, health and other things permitting i'm hoping to start having a garage clear out tomorrow and although the compressor is in my small shed, if things go as planned i should be able to make time and space to get in there and check/photo it tomorrow.
Over the years i've amassed quite a scary amount of spares and can't see me using anywhere near half of them, let alone all of them so the plan is to sort out what i will need and then offer the rest initially on here then fleabay. I'll start a thread for the other bits shortly. :wink: :D
Nuts4my827
Post by Nuts4my827 » Tue May 30, 2017 6:09 am
I have one. Straight of a Turbo car.
Post by SJG » Tue May 30, 2017 12:59 pm
Nuts4my827 wrote:I have one. Straight of a Turbo car.
I have replied to your message Phil
Users browsing this forum: No registered users and 21 guests
