Black Panel behind Windscreen Wipers
Hi,
Recent purchase of 825 Sterling Coupe has had me crawling over the bits I'm familiar with.
This Black panel is severely rusted and needs to be replaced (or sanded & painted - but would prefer a replacement)
If anyone has one, or knows a source for one, please let me know.
I can't remember the technical term for this part, but it's the full width of the engine compartment, and protects the wiper motor housing from memory. There are half a dozen circular black screw covers which pop on to make it a tight fit.
Thanks.
Thanks.
Brian
(wildrover04)
(wildrover04)
- pre_pace
Re: Black Panel behind Windscreen Wipers
I think you mean the scuttle panel? It's a common issue. If so take a look at Rimmer Bros. you might find one there.
David.
1990 R8 Rover 416 GSi
1998 R8 Rover 416 SE Tourer
Hi,
thanks for the responses.
checked on Rimmers, the link given says its for an 88-91 model ?
I want it on my '98 Coupe .... will it fit ?
Brian
(wildrover04)
(wildrover04)
- pre_pace
Brian,
There's been a recent thread on this, a couple of the members suggest that despite the slight differences it should fit, I guess for £6 it's worth a go.
Rovercoup was going to try and fit one to his coupe, maybe it's worth a PM to see if it worked, or what he had to do to make it fit.
David.
I did indeed fit mine and was very straight forward whole thing done in 30 mins. check the thread about these as Brad gave some very good advice.pre_pace wrote:Brian, Rovercoup was going to try and fit one to his coupe, maybe it's worth a PM to see if it worked, or what he had to do to make it fit.
- Tenesmus
Xpart call it a windscreen finisher.
Pete
- Joined: Thu Jan 17, 2013 11:26 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Good luck in finding one. I tried everybody on the part search site and they had all sold there stock.
So I have had to repair my current one with a welded patch and some fillet.
Another 800 part thats obsolute with no common replacment like the petrol fillers.
1998 Rover 820
Sounds a bit fishy.broadaces wrote: So I have had to repair my current one with a welded patch and some fillet.
Seriously, though, the mark 1 saloon scuttles will do the job. I have a few if you can't get one.
Thats auto check on the phone for you Brad. I checkef Thursday and all them listed didnt have them in.
Dont suppose you have any fuel filler pipes or alternatives to a leaky one do you Brad
1998 Rover 820
I do have quite a few fuel filler pipes but none for sale, sorry.broadaces wrote:Thats auto check on the phone for you Brad. I checkef Thursday and all them listed didnt have them in.
I have even more scuttles if you want one of those.
Hi there,
I would like to take you up on your kind offer of a Scuttle.
My mobile no. is {removed}
cheers, and thanks for the offer.....
Reason: Phone number removed
Brian
(wildrover04)
(wildrover04)
Sorry Brian but my offer was two months ago. I have none at all now - some were sold, most were chucked out.
I have no Rover 800 parts for sale at all now. But I do have a lot of space!
- Location: NORWICH [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
i have a pannel £10 slight rust patches quick rub down and satin black,can send pics,
Sounds ideal, drop me the pics, to info@btip.co.uk please.
do you accept PayPal ?
cheers, let me know.
Brian
(wildrover04)
(wildrover04)
