1990 Mark 1 827 Saloon Slave Clutch Cylinder
Dajazar
Post by Dajazar » Wed Sep 02, 2015 7:54 pm
Hi,
These appear to be like hens teeth in the UK :x Unfortunately, mine has given up the ghost. Does anyone have one or know of a supplier? There are a few Masters about but no Slaves.
Does this being a rare manual matter at all or were they fitted with one from an 820/825 or the like?
Tracy
Love my cars
Rover 827 Sterling
Rover 820i Special Edition - Sold
Vauxhall Frontera 3.2V6 Estate Limited- Sold
Rover 618i
Honda CRV
mercedade
Re: 1990 Mark 1 827 Saloon Slave Clutch Cylinder
Post by mercedade » Thu Sep 03, 2015 7:57 am
When I had to replace the one on my Mk1 827, I picked up what I believed was the 'correct' one. However, when it came to actually fitting it, the connection for the hydraulic fluid pipe was at a slightly different angle. However, any garage worth their salt would be able to either bend the old pipe to fit, or create a very small connector piece bent to the right shape for not a lot of ££.
traineefarmer
Post by traineefarmer » Thu Sep 03, 2015 8:03 am
Mk1 and Mk2 would both have the PG2 box, so maybe a later version would fit? There was a man who would know, but he's not on here anymore.
rovercoup
Post by rovercoup » Thu Sep 03, 2015 8:55 am
He is? Dave dollysprint
Rover 827 Vitesse Fastback Mk1 89 (HNR)
Rover 827 Sterling saloon 90 auto (LMZ)
Rover 820 Coupe sport 94 (PMF)
Rover 827 Sterling Saloon 95 auto (COF)
Rover 820 Vitesse Fastback 98 (COQ)
Rover 25 2.0TD 01 (HFH)
Rover 45 1.6 SE 05 (LEF)
MGTF 135 02 (JFV)
Dajazar
Post by Dajazar » Thu Sep 03, 2015 1:37 pm
I've sent Dave a PM.
Tracy
Love my cars
Rover 827 Sterling
Rover 618i
Honda CRV
dollysprint
Post by dollysprint » Thu Sep 03, 2015 9:50 pm
Tracy
I'll answer your PM here if I may so other members can see it.
Pre chassis number 214102 part number CDU2122 SLAVE or Repair kit CDU2331 mk1 825/827
Chassis number 214103 to chassis number 297000 GSY134 SLAVE or Repair kit GRK4012 late mk1 827
Mk2 827 to 1995 UUB10002EVA SLAVE or Repair kit UUL10002EVA
These all cross reference and are genuine parts. There are then a few aftermarket part numbers which were all genuine suppliers to be honest
TRW PJD250
DELPHI LL15126
GIRLING 1104250
HONDA 46930-SG9-E01
A slave will set you back £80-£120, if you get a repair kit it'll be about £20 but the bore of the cylinder must be in A1 condition or it wont seal properly.
Let us know how you get on, sure a few others will need this in the future.
1998 L/R Freelander 1.8 50th Edition 5dr
2005 Rover 45 GSi TD Sonic Blue-destroyed by a wanker
1999 L/R Freelander Di 50th Edition 3 dr
Dajazar
Post by Dajazar » Thu Sep 03, 2015 11:36 pm
dollysprint wrote:Tracy
TRW PJD250
DELPHI LL15126
GIRLING 1104250
HONDA 46930-SG9-E01
Thank you Dave
Much appreciated. I can not find a supply in the UK. The Slave I require is part number GSY134 SLAVE.
I have send an email to a company in the USA called Dorman Products who has it in stock asking how I can purchase it from them.
Will let you know outcome in case anyone else needs a replacement in the future.
Its not in stock at Rimmers and they don't know when or if they will get it back in stock.
Tracy
Love my cars
Rover 827 Sterling
Rover 618i
Honda CRV
traineefarmer
Post by traineefarmer » Fri Sep 04, 2015 7:38 am
There are some Dorman products available on amazon - USA. I recently bought one of their filler necks that way. I'd guess that searching the part number on amazon.com and then shopping around for a seller with reasonable international postage would sort you out.
mercedade
Post by mercedade » Fri Sep 04, 2015 7:56 am
Dave, I just wondered if you'd be able to confirm an 'underlying' question whilst we're on the subject - although you've posted the correct part numbers for the exact part, is it possible to tell how they differ from, for example, the slave cylinder I've fitted to my '98 Vitesse?
I ask because if the only difference is the angle at which the hydraulic line enters the cylinder, but the two mounting bolts are otherwise the same, Tracy may well be able to make use of the more readily available slaves for the later cars.
I honestly couldn't tell you if there was a difference between the ones I fitted to my Mk1 827 and the Mk2 Vitesse.
I ordered the Vitesse slave from my local motor factors who got it within 6 hours for £40-odd plus VAT. If it's that plus some additional hydraulic line, it could be well worth considering rather than waiting for an imported part and/or an outrageously expensive part.
rovercoup
Post by rovercoup » Fri Sep 04, 2015 8:37 am
eBay item number:321706924899
There is the correct part you are looking for in Italy which may be quicker than the states but is not cheap. EBay item number for you.
MGTF 135 02 (JFV)
Dajazar
Post by Dajazar » Fri Sep 04, 2015 7:25 pm
Thanks lads
I will go to my mechanic in morning and have a look at it to make sure I am ordering the right one.
On Amazon UK the Delphi part looks different to the Dorman part.
The one's on Amazon is ABS 51990 Slave Cylinder Clutch @ £78.68 & FREE Delivery in the UK
The one on eBay Cilindro Frizione - Clutch Slave Cylinder DELPHI LL15126 Rover 800 Honda Legend @ EURO 95.00
Approximately £69.23 plus shipping.
Will let you all know how I get on.
Thank you all again
Tracy
Love my cars
Rover 827 Sterling
Rover 618i
Honda CRV
Post by Richard Moss » Sat Sep 05, 2015 7:20 am
Tracy - Dorman products can often be found on http://www.rockauto.com - you may find it there.
Edit:
I've just looked and if you select the make as "Sterling" and model as "827" then select "transmission - manual" there are loads of slave cylinders listed. There is a Dorman CS37890 for $27 plus shipping. Rockauto will post stuff to the UK for $13
That's about £30 all in and possibly worth buying 2 at the same time for future-proofing
Dajazar
Post by Dajazar » Sat Sep 05, 2015 11:10 pm
Right,
Checked with my mechanic and the Dorman part is the correct one. This bears no resemblance to the others at all which is a bit of a mystery so I wonder if Dave could shed some light on why this should be the case, although clearly some 827's do take the other parts:
From Dorman's own website:
http://www.dormanproducts.com/gsearch.a ... origin=YMM
It is cheap enough though as Richard says. I think if anyone needs one in future they will have to see which one fits their car.
Tracy
Love my cars
Rover 827 Sterling
Rover 618i
Honda CRV
N.I.Vitesse
Post by N.I.Vitesse » Wed Aug 09, 2017 10:21 am
Folks
Ordered one for my 827, from Rockauto.com, in the States, ordered Monday and delivered to me on Wednesday, £45 all in.
Great Service.
1996 827 SLI (Manual)
2004 MG ZT-T 190+
Post by scoobyh123 » Wed Aug 09, 2017 10:43 am
Didn't notice the date of the first post so did a bit of digging and found :
http://www.ebay.co.uk/itm/New-Saab-99-9 ... OSwCGVX88h~
Check the cross-reference numbers in the listing, it comes up the same as the Rover numbers, including but not limited to UUL10002EVA.
Like Dave said, the slave cylinder itself needs to be good for a rebuild kit to work.
The slave cylinder is unique to the manual Honda V6 engined 800s and of course the early Legends. As our friend above ^^^^^ says, Rock Auto are pretty good and £45 all in is a lot less than the one i did find in the UK for £108 and likely to be made more recently as well! :wink: :D
