Hi All,
My VCM/trip computer is playing up, I maybe able to fix it, but I want to keep the car on the road while look at it. So all I really need at the moment is a dead one to use to allow the lights etc to work. That said, if I can't fix I'll need to find another one. Any help appreciated.
Russ
Wanted. VCM dead or alive.
- t120v
- Location: pontgarreg ceredigion [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
TVR 350i
Triumph T120V
Triumph T150V
HD FXRPS
Vitesse Mk1c
Triumph T120V
Triumph T150V
HD FXRPS
Vitesse Mk1c
Re: Wanted. VCM dead or alive.
Hi Russ
I have a trip computer, the part numbers are
DCP 8311
2TCVM
Lucas
53987229A
0588
Regards
Ian
DCP 8311
2TCVM
Lucas
53987229A
0588
Regards
Ian
- t120v
Hi Ian,
Thanks for the reply. My trip computer/vcm was made by Borg. I've no idea if Rover used more than one supplier for the tc/vcm but if the one you have is a slimline version and not the earlier large version then it should be a straight replacement.
What do want for it?
Russ
Russ
TVR 350i
Triumph T120V
Triumph T150V
HD FXRPS
Vitesse Mk1c
Triumph T120V
Triumph T150V
HD FXRPS
Vitesse Mk1c
Hi Russ
I don't think this one is very slim, it's more likely to be the larger version, the face is 185mm x 102mm, it's 124mm deep.
Regards
Ian
Regards
Ian
- t120v
Hi Ian,
Yep that's the larger one. Thanks for taking the trouble to reply.
Russ
Russ
TVR 350i
Triumph T120V
Triumph T150V
HD FXRPS
Vitesse Mk1c
Triumph T120V
Triumph T150V
HD FXRPS
Vitesse Mk1c
