Wanted, Rear Bumper for a Rover 800 Hatchback
- Barnacle-Bill
- Location: Dumfries [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
As if I've not got enough to worry about with my Wife being in Hospital with Double Pneumonia and a serious Gastric infection, while I was in visiting her, some rotten so and so smashed into the back end of my car while it was sitting on a Disabled Bay, yes, I am disabled with a Legal Blue Badge, but, they even had the brass neck to lift all the broken body work that had fallen off, I suppose in a vain attempt to make it look as if nothing had happened, good job I had to put my wheelchair in the boot, or I'd never have seen it, so......
I need quotes for a Rear Bumper for a 1999 Rover 800 hatchback, in British Racing Green, if possible, many thanks -
Fred
Rover 800i Fastback
Rover 800i Fastback
Re: Wanted, Rear Bumper for a Rover 800 Hatchback
That's such an unpleasant thing to happen. Sometimes, it's really easy to hate other people.
Hope your wife is doing better as well.
Hi Bill
Can you find the paint code please, it's on a plate by the front passenger door, if you open the door, it's on the centre column, just above the sill.
It should be HAF or HNA, however, knowing Rover it could be something completely different.
Regards
Ian
Regards
Ian
Welcome aboard Fred! Given your location i think your best bet would be these people :
http://www.barremmotors.co.uk/
The bumpers are the same across the range so at least that widens your scope for getting one. I know exactly how you feel though - my coupé was whacked on the front bumper not long before xmas.
I hope both ladies in your life (your wife and 800) make a full recovery very soon! Might be worth asking the hospital if they have any CCTV footage of the "Waste of Oxygen" that dinged your car - you may be able to get some sort of reimbursement from them.
(1997 820Si / LPG)
(1997 820Si / LPG)
I wouldnt pay that much for that bumper...
Dont look in the best condition
Postage is expensive too
Wouldnt worry to much about the motor at the moment, as long as its drivable.
Sounds like your missus needs you more.
Wish her a speedy recovery
Have you still got the coupé shell Dean? Probably the right colour bumper if so...........
I do still have it Dave
Its not British Racing green though
Cant remember the name but its a dark green metalic.
Where would I find the paint code ?
- Barnacle-Bill
Hi Stankerstanker wrote:Hi Bill
Regards
Ian
Cheers for that, the paint code is HNA with the trim being SHJ,
Good news about the Wife, she's in great condition, she's responding very well to these stronger antibiotics the Doctor's have got her on, both IV and orally, her oxygen levels are now a whole lot better, so things are now looking up, and that lessens the strain
A wee thanks to all for your kind words regarding the Wife, your words were very much appreciated
Fred
Rover 800i Fastback
Rover 800i Fastback
The paint code is on the plate at the bottom of the B post on the passenger side Dean (Open the passenger door and you should see a small square-ish plate) - should have Colour and trim codes, the trim should be SMJ on yours as it was Stone Beige but the green carpets might change things somewhat.deano wrote:I do still have it Dave
Is it not under the bonnet too ?
Dont really wanna disturb the plastic windows atm
To the best of my knowledge, no - forgot about the windows!
I opened the door a bit but it was getting dark so I took a quick photo of it on me phone.
Unfortunatly because of the flash I cant see the trim code properly.
Its either.... SNJ SHJ SMJ
But the paint code is deffo.... HAF
Anyone know what colour that is ?
deano wrote:I opened the door a bit but it was getting dark so I took a quick photo of it on me phone.
Trim would almost certainly have been SMJ, the paint code is the important bit here though. The code HAF works out to :
HAF Pearl BRG
http://www.ebay.co.uk/gds/MG-Rover-pain ... 677/g.html
In other words, Pearlescent British Racing Green - Freds car is HNA which is British Racing Green. I wonder how different they actually look and if your bumper would look ok on his car without respraying it.
maybe not much difference in colour....
BUT, being a coupe it has the black bumper tops,
where as Bill or Freds is probably fully painted, seeing as its a 1999 Fastback
