Exterior trim wanted for my vitesse coupe
- Joined: Wed May 11, 2016 8:30 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Good evening everyone. I am trying to source the black plastic trim that runs from between the door and wheel arch above the sill line, passenger side on my vitesse coupe. Would be very grateful if this could be found . Many thanks
Re: Exterior trim wanted for my vitesse coupe
front wheel arch or back ?
( I bet its the back though )
Hi Deano, as you anticipated it's the back. Can you help at all? Many thanks
sorry no I only have a front wing piece left
After selling the bits on ebay , I know from the amount of enquires I kept getting about the rear ones
They often fall off when the glue goes dry and brittle
- soundrediscover
I can probably help?Batman wrote:Good evening everyone. I am trying to source the black plastic trim that runs from between the door and wheel arch above the sill line, passenger side on my vitesse coupe. Would be very grateful if this could be found . Many thanks
Can you collect?
Currently still attached to spares coupe......
Rock On!
Ian
Ian
Hi Ian,
I'm based In Kent, whereabouts are you? I'd definitely come to collect the elusive trim if we are reasonably close to each other.
Thanks for your reply
Batman
Batman
read your pm, which was sent a while ago regarding this part
- soundrediscover
Leicestershire!!Batman wrote:Hi Ian,
Batman
I'll take a photo to see if it is the part you are after and have a look for a loose part - there is an outside chance I have one in a pile of sundry bits in the corner of the garage.....
Rock On!
Ian
Ian
