thermostat
- Joined: Mon Sep 14, 2015 3:41 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
thermostat
Hello there,Any body got a spare thermostat housing(the part that bolts onto engine) i req. one rather urgently,mine has stripped threads.Thank you all in advance
Re: thermostat
erm.....
knowing on what type of engine , model or year would be a start
Re: thermostat
EM......Yes my mistake.....1996 820 sli manual with a/c.(was very rushed)
Re: thermostat
Just for identification, is this the bit you're after?
http://www.ebay.co.uk/itm/Rover-T-serie ... SwMNxXVZ3L
Might be worth renewing the 'stat and the antifreeze at the same time.
Re: thermostat
No mate its the bit that the elbow bolts onto then bolts onto engine block.The bolt holes in this housing have stripped corroded so
if no one has a spare it will be a machine shop job,but thank you for your interest.
Re: thermostat
In that case we're looking at Item #9 in this diagram then ?
http://www.rimmerbros.co.uk/Item--i-GRID004516
I can probably lay my paws on one but won't know for sure until later today.
Re: thermostat
Hello Tom,As my previous info my 820 sli manual with a/c 1996 the housing below the thermostat elbow one bolt was corroded,on removing
it very gingerly i noticed the ally threads were gone and so was the gasket underneath.I tried Rimmers no joy and i have tried 7 local
breakers........sorry no 800s never had one for ages.Thank you..........ERNIE (scoobyh123 has also replied he might be able to help)
Re: thermostat
Hello Scoobyh123,Yes thats the one Cheers ERNIE
Re: thermostat
Hi Ernie,
it sounds like Tom can find his quicker and easier than i can so if you send him a PM (Private Message) you're likely to get a quicker result.
Little tip for when you put it all back together - smear some copper grease over the outside of the bolt threads o prevent corrosion between the aluminium casting and the steel bolts. That should prevent the problem coming back.
FYI the housing is the same on cars with and without A/C.
