fuel tank for1995 820 fastback wanted.
- Joined: Thu Jan 30, 2014 2:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
failed MOT only on petrol tank leak.Cant locate one.looks like a real struggle to get it off and local garages dont want to know.Now Im 70 its not a job for me but repair or replace I would like to keep my otherwise lovely low mileage car on the road,alternatively does anyone want to buy an otherwise excellent low mileage car.(best of british cant help).
.regards Rod Jones Halesowen.West Mids
Re: fuel tank for1995 820 fastback wanted.
After a quick Google it does seem difficult to find one easily. Rimmer Bros don't have any and the usual suspects I would try don't list them.
Ebay would then be the next obvious choice and there's only this one.
http://www.ebay.co.uk/itm/petrol-tank-f ... SwdzVXrXGs
Even that one's probably one of your old ones Chris
Almost certainly, I was trying to remember which car it was off.
I have one for sale off a low mileage 1999 car. Still need to remove it but have doused the studs with WD40 so hopefully won't be too bad. Also has a working fuel pump already in it that would be suitable for a n/asp 820 but not a turbo version.
Also got a reasonable filler neck with it, could do with a wire-brushing and black hammerite or similar but appears intact.
Either or both at a reasonable cost, not sure about getting the tank to Halesowen as many couriers won't take fuel tanks of any description unless they are brand new because of the risk of fire etc from fumes.
- soundrediscover
I have one which will be Ok with a clean up.
Market Harborough is not too far if wanting to collect, or I can take into work (Coventry just off junc 2 M6)
I'll see if I can get a picture up tomorrow....
Rock On!
Ian
Ian
ian- thanks for your message re 820 tank.Im hoping local garage can fix (codge) it to make it roadworthy since my only other transport at the moment is an old volvo 240 which just gets to the shops and back.Could I email or phone you if necessary?
thanks for your help ..regards rod.
- soundrediscover
Hi Rod,rod jones wrote:ian- thanks for your message re 820 tank.Im hoping local garage can fix (codge) it to make it roadworthy since my only other transport at the moment is an old volvo 240 which just gets to the shops and back.Could I email or phone you if necessary?
have sent contact details via PM
Rock On!
Ian
Ian
Ian...820 fuel tank is required as suggested,but I cant find your PM regarding a contact number or e.mail address.I havnt used this system
before so perhaps its me.My e.mail is rodders66@live.co.uk or tel 07905 174979 .Sorry to be a nuisance.
Rod
Rod
