Scuttle panel, the metal full width one
Wanted, metal scuttle panel that runs the full width of the base of the windscreen and covers the base of the windscreen. Needed for a 1997 fastback.
Also need the metal plate that goes above the brake servo.
Manual leather gear knob.
Dimpled leather steering wheel for a vitesse.
R750 cd changer controller stereo
Re: Scuttle panel, the metal full width one
Can't help with the first two, might have a steering wheel though.
As for the gearknob, this was covered in another thread some time back and from what i remember, the Rover ones are NLA at Rimmers, secondhand ones are scarce (especially in good condition) so what most people have done is used ebay :
https://www.ebay.co.uk/itm/Universal-5- ... 2250054050
https://www.ebay.co.uk/itm/Black-Blue-L ... 1262197594
https://www.ebay.co.uk/itm/new-Universa ... 2925873926
A few to choose from there - search for Range Rover or Freelander manual gearknob, they used the same ones originally i believe. They're listed as different part numbers but fairly confident they're the same under the parts label.
I've got one or two stereos with CD changer control, not sure of the exact model numbers though.
Whereabouts are you based? I'm in Manchester/Stockport, and have a couple of scuttle panels - but transport will be a bit of an issue!
Excellent. If I get a decent photo of my stereo can you take look and see if you have a match? And have you got the codes?scoobyh123 wrote: ↑Sun Jul 22, 2018 3:38 pmCan't help with the first two, might have a steering wheel though.
James
Oh and can you check for a steering wheel. I need s late airbag one with the dimpled leather.
I’m in the south east! Bummer. I occasionally travel up your way so will keep you in mind. Don’t suppose you are going to the Peterborough show on Sunday?
I'm fairly sure i've got the code, if i haven't then it's just a box so won't be any help to you. What's the problem with your existing stereo?
I haven't found the steering wheel yet but i did find a pair of Mk1 Vitesse wheel spats, i'll have a look soon at the Stereo i've got to see which model it is.
Hi nitro,
I have a spare scuttle, a steering wheel and radio with code and will be attending the BMC show in my black coupe.
If you don't get parts by then let me know and I can bring them with me. I also have a reasonable leather gear knob too.
Steve
Steve
This is the stereo I need. I think its an R750, but importantly it says CD controller across the top. I think there were other similar looking units but that couldn't control the CD player.
R960 It should say it on the red lettering at the top there .
There is also a R950 with only 5 preset buttons instead of 6
There was a R750 but i think that may have been without the CD funtion
That is as Dean says an R960 James and coincidentally the same as the spare one i have. Only thing is i can't find the code for it at the moment, i think i know the code but need to refit the buttons to try it!
If it doesn't work you have a good offer from Steve for a radio with code, steering wheel and a gear knob and i believe a scuttle panel as well on your scuttle panel thread.
Just checked and your right it is an R960. Anyone got one in working order with the code?
I think Steve has the answer to your prayers James!
I'm afraid not, car shows have never really been my thing. I like having a wander round the local ones where you get a proper weird mix, but never managed to drag myself further than a few miles!
