Front and rear suspension and sub frames
I want to rebuild the suspension on my mk1 827. Ideally I would like to build up complete axles and the fit in one go. So I am looking for a good second hand set that I can strip, paint, rebush and then refit. Anyone got anything? And would also like to upgrade to later vitesse sport spec if possible or just antiroll bars.
Re: Front and rear suspension and sub frames
I've got most of the front end set up James including a rack. The bushes are Polybush i think but need replacing, as far as i can tell the rest is in reasonably good condition. There's an anti-roll bar there, think it's the 23mm rather than 25mm version but the bushes are ok and will still give an improvement over the 19mm that i suspect you've already got.
If you're interested, i'll get some photos.
Back end i have very little left but if you have the front end we should be able to find some back end bits after.
Drop me a PM if you're interested.
