I need one for my 98 Vitesse (w/ air con)
Although I don't know the details yet, it seems the pump on mine is knackered. I've been exploring refurbs, but I don't currently know the actual problem with mine, so until then I'm looking for new/exchange units.
Anyone got any leads by any chance?
T series power steering pump
Re: T series power steering pump
There was a thread on here recently Adrian, someone had a similar problem and there no PAS pumps left in the world it seems, not for your engine anyway.
However, what the person who started the thread found was that a 25/45 (diesel i think) PAS pump not only fitted with a tiny mod but worked and was the same basic pump.
I'll see if i can find the thread.
*** EDIT ***
Found it quicker than i expected! It's about the 3rd or 4th post down, part number in a later post in the same thread :
viewtopic.php?f=9&t=14592
Apparently you have to bolt on a pipe fitting a different way, hence the different part number ..............
*** EDIT ***
This is GREAT NEWS.
Thank you Dave - and thank you Rob, if you ever see this thread.
You're welcome Adrian - good to have these alternative parts as 800 stuff is getting hard to find now!
