Rover 829 grill
SEGUBJO
Rover 829 grill
Post by SEGUBJO » Sat Apr 27, 2019 9:18 am
Hi there!
Looking for a good 820 grill with all the bolts still there
Best regards
Gunnar
Re: Rover 829 grill
Post by scoobyh123 » Sat Apr 27, 2019 10:27 am
Hi Gunnar,
are you looking for a pre-96 or post-96 grille? Finding one with all the bolts is going to be a challenge though. Most corrode and/or shear when the grilles are removed.
SEGUBJO
Re: Rover 829 grill
Post by SEGUBJO » Sat Apr 27, 2019 2:38 pm
It is for my 1995 Rover 820 ti
Re: Rover 829 grill
Post by scoobyh123 » Sat Apr 27, 2019 3:47 pm
That would be the chromed metal surround with the (painted) black plastic slats insert then. I'll have a look, i know i have a few grilles around, one of which i'm saving as one to fit to my Sterling (it currently has a post-96 chromed plastic surround with the pale plastic insert), another came off my Sterling and has sheared bolts which i may be able to remove (haven't tried yet) and i think i have another somewhere.
It'll be tomorrow at least before i look as Storm Hannah is making life a bit wet and windy here at the moment.
SEGUBJO
Re: Rover 829 grill
Post by SEGUBJO » Sat Apr 27, 2019 5:57 pm
Thanks a lot Dave, look forward to hear from you!
Cheers
Gunnar
Users browsing this forum: No registered users and 30 guests
