Subframe/cross member bolts
mercedade
Post by mercedade » Tue Oct 22, 2019 9:10 pm
Anyone got a couple (or just one!) of the stumpy but chunky bolts that connect the front-to-back beam under the engine and gearbox to the front subframe?
I've got one that's a proper mess and will probably get ruined in the process of extracting it tomorrow - just seeing if anyone had any in their pot of nuts and bolts :)
https://rimmerbros.com/Item--i-EDP3533
They're dirt cheap from Rimmers but Christ, the P+P :shock:
Re: Subframe/cross member bolts
Post by scoobyh123 » Tue Oct 22, 2019 10:41 pm
I think so, i'll try and find some tomorrow if i have. Do you know the thread size? I know the head is 13mm but it's a flange bolt so normally the thread size is the next size up which would make it M10 - seem to recall the thread was M8 when i removed some of mine some time back.
Post by CHR15E » Wed Oct 23, 2019 3:09 am
Use it as an excuse to order more bits and make the postage more palatable?
mercedade
Post by mercedade » Thu Oct 24, 2019 10:23 am
Yeah....I could, except (famous last words) I think I've finally ordered everything I need!
mercedade
Post by mercedade » Thu Oct 24, 2019 1:47 pm
Dave, that's be fantastic, thanks.
Thread and diameter wise, they're the same as the exhaust studs, if that helps!
Post by scoobyh123 » Thu Oct 24, 2019 6:54 pm
I read that and thought "Yeah, that's great, they're M10 x 1.25, easy enough to make sure i get the right ones!"
Then i remembered yours is a 2.0 so has different sized exhaust studs!
Too wet for me to even think about taking one out of mine to double-check and haven't found the right looking bolts yet in the tubs i've investigated so far.
I'll keep looking as and when weather allows! :wink: :D
mercedade
Post by mercedade » Thu Oct 24, 2019 9:03 pm
Cheers Dave.
I'll be allowed to drive in a few weeks (foot operation) so if no joy, I can drop in a hardware shop and see if they've got something that'd do the trick.
Post by scoobyh123 » Thu Oct 24, 2019 9:18 pm
Cheers Dave.
I take it you're non-weight bearing and trying to hobble around on crutches then Adrian?
If so, i have something i was about to list on ebay that would be very helpful for you. If you're interested, drop me a PM and i'll explain.
Meanwhile stop hopping around on one leg, you're making it rain! :P
mercedade
Post by mercedade » Mon Oct 28, 2019 8:45 pm
Cheers Dave - I was, for the first three weeks. Then, for the last three weeks I've been able to walk in my special sandal, hence all the sudden progress on the Rover.
Now out of the sandal and into normal shoes - another couple of months and I'll stop limping so much.
mercedade
Oh, and cross member - in the end, I was able to get to the hardware shop and picked up an M10 set screw. It does the job, so another one crossed off the list.
Post by scoobyh123 » Mon Oct 28, 2019 10:17 pm
Glad you're back on your feet (literally!) Adrian! Take it easy though and don't do too much, all too easy to cause permanent damage without realising it!
Good news you've got some bolts too, still haven't found the ones i thought i had, only one tub left to investigate and that's bured at the back of the shed! :shock:
