Steering Rack Needed
guru
Post by guru » Mon Oct 28, 2019 11:33 am
Just wondered if anyone has or knows where I can get a steering rack for my mk1c Sterling? The cars undergoing restoration at the moment and needs a replacement however this is proving hard to get!
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mercedes C300 Hybrid
2015 Mini Cooper SD
Re: Steering Rack Needed
Post by scoobyh123 » Tue Oct 29, 2019 12:56 am
I have a secondhand one James, it was working when removed and has been stored outside under cover since.
Any good to you?
guru
Post by guru » Tue Oct 29, 2019 10:10 pm
I think I've found a refurbished one which should be on it's way now however if it's not the right one I'll take you up on that.
Parts were a little tricky to get when I started running the Sterling back in 2006 and the situation in 2019 is as expected a lot worse!
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mini Cooper SD
Post by scoobyh123 » Wed Oct 30, 2019 7:38 am
It came from an early Mk2 which if memory serves, uses the same rack as the Mk1c. All the racks for the Honda V6 engine tend to be fairly similar so you should be ok with the one you've got coming, unless it's for a non-Honda V6 powered 800.
Are you renewing the rack mounting rubbers at the same time?
