Fuel pipes across tank needed (corroded = MOT fail)
soundrediscover
Post by soundrediscover » Sat Nov 23, 2019 12:08 pm
As with my post in the technical area......
The MOT failure is because they leak - my spares have also rotted through.
It is another case of either finding a used set or looking at how to remanufacture.
Any ideas?
Many thanks
Rock On!
Ian
mrwilks01934
Re: Fuel pipes across tank needed (corroded = MOT fail)
Post by mrwilks01934 » Mon Dec 30, 2019 1:02 am
Hi had the same problem just make them out of copper pipe like I did I think there is two sizes involved 8mm and 10mm but to be safe just measure the outside diameter of the old pipe.
Regards Tony
Hi iam Tony, I currently have seven 800's a 1996 827 sterling, a 1996 820 vitesse turbo, a 1989 827 vitesse manual which needs a part/full resto, 1999 KV6 sterling,1998 KV6 sterling, 1998 vitesse turbo,1991 H Reg 827 vitesse Auto all fastbacks.
Post by Richard Moss » Wed Jan 01, 2020 2:33 pm
Will rubber pipes not do the job, temporarily at least?
mrwilks01934
Post by mrwilks01934 » Tue Jan 21, 2020 11:02 am
You could try rubber as an alternative, I remember in the early noughties I went to a rover dealer when you could still get the pipes new they wanted £88 plus vat back then?
