Are front brake hoses handed? I'm looking at Rimmers because I need a right front (or at least, I think I might - I'm getting some random binding, but the pads move freely, as does the caliper on the slide pins), and they seem to list different numbers for LH and RH. Can't work out why though.
If I'm going to get the caliper off to check the piston, I might as well do the hoses as well. Ebay only seems to have LH...
Front brake hoses
Front brake hoses
Re: Front brake hoses
Left Hose : https://www.autodoc.co.uk/abs/7795204
Right Hose : https://www.autodoc.co.uk/abs/7796018
You're right about ebay, none on there at all!
HI Dave,
I'm pretty sure the one you've linked as right hose above is actually a rear hose!
I think I've found one on ebay, but I would rather have bought a matched pair tbh.
They have all 4 hoses in stock Adrian, it's highly probable the webmaster mixed the photos up!
The part numbers seem to make sense as well, i'd suggest ordering a pair and comparing them, if they send the wrong animals then it's down to them to sort out at their cost.
