Anyone got an NSF indicator lens for a 99 fastback or saloon?
The Green Machine needs one and I've used the pair I got from Dave. It looks like the glue has failed and the Perspex has parted from the body. No doubt from that bump my Son denies happened...
NSF Indicator Lens Mk2
Re: NSF Indicator Lens Mk2
Cancel that, Just found one on the bay of E after not finding one earlier. In fact I have now found several after using "Passenger" instead of NSF.
Excellent work
Always pays to try some alternative search terms! The lens can be glued back on to the housing if you have it. The glue does fail though, i had two (one right, one left) that the glue had failed on, i pulled the orange filter out, used self adhesive film to recreate the silvering on the reflector and refitted it all (without the orange filter) with a different bulb holder and a dual LED so i now have DRLs that turn of while using the indicators and come back on a few seconds later.
That was for testing the front fogs but you can see the DRLs.
