Hi All,
Anyone have a camshaft position sensor available for Rover 827 2.7L?
I believe this is the Honda part number 37840-PL2-026
Mine is fried
Thank You,
Jason
Need Rover 827 Cam Position Sensor
- Location: USA Seattle, WA [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Jason: 1989 Sterling 827 SLi
Re: Need Rover 827 Cam Position Sensor
Is it bringing the PGM-Fi warning light on at all? Also any codes flashing on the PGM-Fi ECU? They're near enough extinct from the major suppliers now so if that one is still ok electrically, i'd suggest getting some potting compound, cleaning that up and then repotting it.
https://www.ebay.com/itm/293461103053
That's the sort of stuff.
Once you've done it and refitted it, pull fuse "S" from the underbonnet fusebox for 30s or so and refit.
