SRS Controller
- whitelion58
SRS Controller
Hello
I have the problem with the SRS light staying on - my own fault because I reconnected the battery with keys in the ignition. Very annoying.
Anyway, wonder if someone has a replacement (working!) unit?
Its a 94 827 Coupe automatic, and the SRS unit has this number moulded into the top:
YWC10151
By the way - its the yellow box mounted behind the radio, on top of the tunnel. Easily removed with two fasteners.
PM me if you are able to help.
Thanks
Tim.
YWC10151
Thanks
Tim.
'86 825 Sterling Saloon
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
- whitelion58
Thanks for the replies. There were several variations, so its probably important that the part numbers match exactly..
Its an appalling design flaw that reconnecting the battery with the keys in the ignition is all it takes to send the unit into a permanent error state.
Back in the days when there were Rover dealers, it was possible to have them reset ( it was suggested the procedure was similar to a landrover defender and cost around £100!) No idea how to find anyone with the equipment to do it now though - hence looking for a replacement unit.
Cheers
Tim
Cheers
Tim
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
- whitelion58
Probably. The difference is 1 or 2 airbags, and also pre-post 96.Freewheel wrote:Are 2.0 and 2.7's the same part no?
Not me. Matt in Telford (trades as e.b.a.y. surplus on ebay) may have one. Mo has his phone number.whitelion58 wrote:Nobody out there got one??
- Kyle
pre 96 are much larger, I'm not sure the unit differs for 1/2 airbags, it may only be the loom, but Rich may know better than me?richard moss wrote:Probably. The difference is 1 or 2 airbags, and also pre-post 96.Freewheel wrote:Are 2.0 and 2.7's the same part no?
- whitelion58
just to close this one - I got a replacement unit from another 94 827 twin air bag. Disconnected battery, keys NOT in the ignition. Fitted it, hooked up the battery and all is perfect again. Good result.
Tim
Tim
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
- Location: AUCKLAND NEW ZEALAND [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: SRS Controller
Hello 'white'
This is a reply to an old message and i'm not sure if you'll read it. just to say 'thanks' as you've led me to a solution with my own car.
Regards
Michael
Regards
Michael
