2x RATTY MK1s for sale
- Alex SBY
- Location: Devon. [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: 2x RATTY MK1s for sale
I'll see what condition the lights are in Gordon and let you know. The window motors on the 820 are all shot but I'll have a check on the 827 and see if they work.
None of these bits will be dear.
One or two 800s...
The 827 manual has (or certainly had, at any rate) a decent exhaust from top to bottom. I changed the downpipe for a non-flattened one about 18 months/2 years ago which would mean, among other things, that it should be fairly easy to remove the full system by only undoing 5 bolts (one snapped, wouldn't you know...) which have been loosened more recently than most.
That, and the Koni shocks are decent kit. Just need to find someone who wants to have a play with a Mk1 827 now!
- Alex SBY
Fortunately the 827 is still at my mechanics place and I was going to ask him to remove the exhaust and konis before it gets cubed.
One or two 800s...
- vito
- Location: Lincolnshire & Enix, España [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Alex could I gently remind you about the rear drivers side seat belt buckle in grey if possible
- Joined: Sat Oct 12, 2013 3:02 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Alex,
Hi. I sent you a PM and I don't know if you got it OK.
I have a buyer who is definitely looking for an 827 - even a ratty one!
Could you let me know you got the message pls?
Thanks
Greg
Thanks
Greg
- Location: North Herts [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I've missed this somehow...if the 827 is still available I'm interesred.
pm on it's way.
pm on it's way.
'91 827 SLi Fastback - back on the road at last.
'89 Sterling - work in progress.....
'99 Sterling - on loan
Users browsing this forum: No registered users and 20 guests
