Bottom Ball Joint
- 47p2
- Moderator
- Location: Caledonia [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Bottom Ball Joint
1 only for sale. Brand new, never fitted
Keep one spare, you never know when you might need one
£10 plus postage at cost
JT
Re: Bottom Ball Joint
Sound advice indeed.47p2 wrote:Keep one spare, you never know when you might need one
- JulianO'Connor
- Location: Norfolk [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Froze by backside on Saturday trying to work on mine. One of my bloody wheels was glued on and took three quarters of an hour to free off. Then, with my longest bar and considerable weight on the end, the hub nuts would shift at all. Can't afford an impact wrench that does 300 lb/ft so off to the garage it is
At least I know the parts are good and the right price, shame I couldn't actually fit them!
aka The Serpent
1972 MG B GT
2004 Subaru Legacy Tourer
2008 Subaru Justy R
1972 MG B GT
2008 Subaru Justy R
Always a good idea to have a smear of copper grease behind the wheels to stop that.
Or what I used to do on scrap cars was to loosen the nuts half a turn and then drive it moving the steering wheel a lot. They always came free then.
I don't find my impact gun moves them anyway TBH. I use a 3/4 drive bar and socket and then usually a 5 foot pole over that. Once it's cracked then I use the gun.
- JulianO'Connor
Stupid thing is that wheel had been off recently for tyre fitting. It's had a good greasing now. I'd been donkey kicking it and wacking it with a hammer wrapped in a rag, then I tried wedging a brick between it and the curb and dropping the car down again - it didn't care, in the end turning the wheel to full lock with a quick drop did it. Stupid thing to waste all that time on.CHR15E wrote:Always a good idea to have a smear of copper grease behind the wheels to stop that.
There's a big difference in impact guns, the £80 kind only do a bit over 100 lb/ft - with a good grip I can do that with one hand! After that it's anywhere between £200 and £500 The biggest bar I've got is 1/2" drive and I haven't got a scaffolding pole so I'll just have to surrender I reckon. I did think about pointing the bar forward and down then driving the car forward.. slowly..CHR15E wrote:I don't find my impact gun moves them anyway TBH. I use a 3/4 drive bar and socket and then usually a 5 foot pole over that. Once it's cracked then I use the gun.
aka The Serpent
1972 MG B GT
2008 Subaru Justy R
1972 MG B GT
2008 Subaru Justy R
- JulianO'Connor
They way I see it, they book says they should be put on at 300 lb/ft - therefore with a bit of corrosion you're looking at over that to get them off again.
How come they require that much torque when a lot of other cars use half that? Some Hondas included!
aka The Serpent
1972 MG B GT
2008 Subaru Justy R
1972 MG B GT
2008 Subaru Justy R
- The Flying Dutchman
- Location: Ihren, Germany [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Copper grease and ABS-sensors aren't very good friends. And they are rather close, so be careful.CHR15E wrote:Always a good idea to have a smear of copper grease behind the wheels to stop that.
Job.
'73 P5B Sal.
'94 220 Coupe
'96 220 Coupe
'95 827 Coupe
'97 820Si
'99 600SDi Classic
'69 Herald 12/50
'73 P5B Sal.
'94 220 Coupe
'96 220 Coupe
'95 827 Coupe
'97 820Si
'99 600SDi Classic
'69 Herald 12/50
- JulianO'Connor
Fair point, never had any problems though.The Flying Dutchman wrote:Copper grease and ABS-sensors aren't very good friends. And they are rather close, so be careful.
Use it on the bolts for the brake carriers as well, so even closer.
- 47p2
- Moderator
Now that the mechanical lesson is over we will resume normal conditions
JT
