I have just had a bit of a root around the box of 800 bits and have found the old igniter. It has the number 8524 in white on the top, then on a "step" down OKI with MNE-311 embossed underneath. That appears to be all in the way of numbers.
Don't know whether that is any help?
Garage Clearout of 800 Spares
- mjc9967
Re: Garage Clearout of 800 Spares
Hi Dave,
Hope the rest of your travels went well the other day and thanks for the bits.
You're welcome Mark!
Found the other places i had to go fairly easily, the traffic home was a nightmare though! Those three characters "M25" spell trouble, grief and delay!
Was good to meet you and put a face to a name and also see your beautiful trio of cars and meet your two friends.
- Location: Bielefeld, Germany [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Do you have a pair of rear suspension top mounts mate? Early or late doesn't matter as long as not one of each.
Regards
Ian
Regards
Ian
Hi Ian,
you mean the weird sort of triangular shaped bit with a tube in the middle that the shocks bolt into and the triangular shaped bit bolts to the body?
I'll have to have a look, probably is the answer at the moment. If i do, they will be Mk2 bits though.
