1998 Sterling 825 for Breaking / Project
- PhilC
- Location: Manchester [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Guys
link to my car. 52K miles
http://www.rover800.info/forum/viewtopic.php?t=2585
After speaking with some local mechanics. I can't get the cost of doing the head gaskets down to where I want it to be by doing most of the work myself. I don't have anywhere suitable to put this car to keep as a long term project or as a breaker therefore its available if anyone wants it.
PM me if you are interested.
FYI it has a new battery, new radiator, new thermostat, new air filter, new yellow expansion tank cap and a working expansion tank.
1998 Rover Sterling 2.5 (Gone to car heaven)
2014 Ford Fiesta Titanium X
2003 Mercedes SL350
2009 Vauxhall Zafira 1.8 Elite
1983 Jago Geep 1.6 (Ford Xflow)
1985 Yak 52 (Group Share)
1968 Reims Cessna 172H (Group Share)
2003 Mercedes SL350
- PhilC
There is an alternative.
I've got 5 weeks left before I go back to work. I can leave it insured and taxed on the road and break it for parts (engine bay and interior). Just spoke to a chap who will pick up the lump after that.....and give me cash
Anyone interested?
Phil
Anyone interested?
Phil
2003 Mercedes SL350
2003 Mercedes SL350
- Seans Dad
Phil,
How good is the front grille(any rust?), and how much would you want for it?
Dan.
Dan.
1999 Mercedes C Class C240 Sport Auto Estate.
Previous Rovers: '94 827 Sterling Fastback Auto, '91 820si Fastback Auto.
http://www.mgt-dist.co.uk
- The Flying Dutchman
- Location: Ihren, Germany [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
- PhilC
Precisely...
Dan
Just had a look and its perfect on the outside apart from a spray over spill on the bottom edge that not really noticeable until you look closely. I can remove it with my finger nail (see picture) Just taken the surrounding rubber off and that's in good nick. A tenner plus P&P would be worth my while
Let me know
Cheers
Phil
Dan
Let me know
Cheers
Phil
2003 Mercedes SL350
2003 Mercedes SL350
- Seans Dad
Thanks Phil. I've sent you a PM.
Dan.
Dan.
- PhilC
Guys
Had chance to catalogue the bits I've taken off - cars now gone
PM me if you are interested in anything
- Expansion Tank – Used & OK SOLD
- Yellow Rover cap for the expansion tank – Barely used SOLD
- Air Filter New (out of the packaging) (LX719)
- Halfords Oil Filter (New) – HOF231
- Fuel Filter SOLD
- Coolant Hose – New (in packaging) Radiator to thermostat –
PCH112280EVA
- 4 OFF O rings– New (in packaging) For Thermostat – coolant pipe–
CDU3858
- 2 OFF O rings – New (in packaging) For top inlet manifold –
LYX100230EVA
- 2 OFF Plastic clips New in packaging – PCY101320
- 2 OFF Bolts New in packaging – Inlet manifold – FB110075
- Two radiator fans (complete assembly) Used – Were working OK
- All the engine breather pipes (plastics tee piece broken) Used
- Cruise Control Unit; hoses CU to throttle body; diaphragm actuator unit
(worked perfectly)
- 6 High tension Leads – Used Worked OK
- Cooling System bleed hose to exp tank c/w clips and good plastic tee
piece – PCH112630EVA
- ECU (Complete) Used MKC103660
- Twin Pack relay – Used - Air conditioning (unknown status) YWB100800
- Stepper Motor Assembly Used - MGM 100130
- Sensor Multi point Injection - Used MHK100490 OK
- 6 CD Automatic Changer – XQE10010 Used (worked perfectly with
bracket & screws)
- New Radiator SOLD
- Used Haynes Manual Rover 820, 825 & 827 petrol - 1986 to 1995
- Inertia switch multi point injection – MHQ100130
- Two working key fobs (one fob with one rubber cap missing but still
works OK
- Fuseboard Complete – All electric were working on the car
- Relays (Yellow) 3x R6J6 3 x R6JO
- Relays (Green) 2 x R6JO, 1 x R6J9
- Winscreen Wiper Motor Assembly plus crank SOLD
- Flasher Unit DRC8626 19 FL 12V from under the dash
- Sensor - camshaft – engine short pin – NSC100380
Cheers
Phil
- Fuel Filter SOLD
PCH112280EVA
CDU3858
LYX100230EVA
(worked perfectly)
bracket & screws)
- New Radiator SOLD
works OK
Cheers
Phil
2003 Mercedes SL350
2003 Mercedes SL350
- Seans Dad
Did you manage to get the grille off Phil?
Dan.
Dan.
Sy has some late Vitesse ones that he had off me.MikeMedford wrote:Damn that was quick, was interested in the door cards
- PhilC
Mike et alMikeMedford wrote:Damn that was quick, was interested in the door cards
I asked the salvage company to hold off crushing it for a few days to give you guys a chance if you wanted anything
BS Salvage 0161 799 2185 - Walkden Manchester- they'll do mail order
What I can tell you is that the Bonnet, front wings were very good. ONe doore had a rust spot at the top (rear offside), also plenty of key marks by the locks. Bumpers were marked in the four corners and the rear bumper was marked in the middle. None bent all could be recovered to new condition. Interior was spotless (mats were slightly marked but scrubbed up well)
2003 Mercedes SL350
2003 Mercedes SL350
- Seans Dad
No grille then?PhilC wrote:Mike et alMikeMedford wrote:Damn that was quick, was interested in the door cards
Dan.
- PhilC
Sorry Dan
there was a one stud and nut that just rotated. Stupid fixings!! should just be screwed on - simple plastic part - very little pre-tensioning required. Just couldn't get it done it time. Awkward to hacksaw
Phil
Phil
2003 Mercedes SL350
2003 Mercedes SL350
Users browsing this forum: No registered users and 24 guests
