Believed to have done less than 70,000 miles, this engine was originally fitted to a mk1 420 before being installed in a mk1 820.
I has had an "M" series flywheel fitted (for the 820) so can go straight into an M series powered car (mk1 820, early mk1 420 or early mk2 220 up to about 1991) or, if you fit your T series flywheel it will go into later 220, 420 or 820 models (approx 1991 onwards).
There's no alternator or PAS pump but it's otherwise complete, and is fitted with a PG1 gearbox (as used on mk1 820s) although the input shaft on the box is noisy. It was smooth and quiet when I last had it running a few months back. Starter motor, crank position sensor, injectors etc. all included.
The engine is located in North Yorks (about 15 miles south of Scotch Corner) and I'll be looking for about £50 or so - but am open to haggling! PM for any more details or to make an offer.
Thanks
T series 2 litre engine
Users browsing this forum: Google [Bot] and 22 guests
