rover 827 igniter and header tanks
- Location: NORWICH [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
i have a rover 827 igniter(£25 inc post uk main land £20 if you pick up) and 3 header tanks for sale(28 each inc post uk main land £20 if you pick up)
Can anyone confirm of this igniter will be suitable for my Mk1 827 manual?
Can't think of any reason why not, but could do with confirming!
Cheers
Cheers
The backing plate can vary in thickness, worst case you made need either spacers are longer bolts if one is thicker than the other.
Aside that you'll be fine.
