I would prefer a vitesse but this don't look too bad
http://www.ebay.co.uk/itm/1999-ROVER-82 ... 337c09a0d8
Your thoughts on this
- 47p2
- Moderator
- Location: Caledonia [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Your thoughts on this
Well that makes me think the owner is a manky barsteward straight off...Not a good startThe interior is very good needs a clean
If there is rust there then expect more rust elsewherethere is a rust patch under the paint on the n/s/r wheel arch
Was the water pump changed when the head gasket was done?including a head gasket and cambelt change at 109k
Included are some spare's including switches trim parts water pump and some gasket's
Personally I think it sounds a bit of a dog and worth about half what he's asking, it has a short MOT and almost no road tax.
I'm sure you could find better for the same money
JT
- Tenesmus
1999 but not colour coded???
Pete
its a Coupe Pete, no colour coding
- Location: Newcastle Upon Tyne [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
If you want a Vitesse wait for a Vitesse miles beter engine dont want no Ketle wel not one that is nackerd after one boil any how!!
