Original Rover Manuals and Videos
- BlueRover
Re: Original Rover Manuals and Videos
Gregory's Girl ... Brill !!
- whitelion58
Thanks to Charles Weaver for loaning the 1992 Thatcham Methods Manual for the Mk2. This is the book used by insurance assessors that gives standard methods and times for all body repairs. Not hugely relevant to the average rust repairs we are involved with, but a fascinating and detailed description of how the things are put together. Now uploaded to the Manuals section so thanks again to Charles.
'86 825 Sterling Saloon
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
- TheVDM
I have a photocopy of the PG1 & PG2 overhaul manual and the dedicated T-Series overhaul manual if you're interested in adding it to the directory, just pm me an email address and I will forward it on.
- whitelion58
Jim kindly sent me the two manuals. The gearbox overhaul was a direct copy of the relevant chapter of the workshop manual already on the site, so I have not uploaded that.
The T-series manual was a new variation though, so that has one been included. Thanks Jim.
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
- TheVDM
Oops, I didn't realise, it was just the chapter out of the main manual.whitelion58 wrote:Jim kindly sent me the two manuals. The gearbox overhaul was a direct copy of the relevant chapter of the workshop manual already on the site, so I have not uploaded that.
I am currently working on cleaning up the PDF files to make them a easier to read as I am slowley printing them bit by bit and binding them into folders as I despite being a computer nut I prefer my manuals in paper (I know I can buy them online, I'm just stubborn). Once they are done I can forward them on too if you like.
Edit: I also have the Haynes 820 workshop manual which is a little different to the service manual (it only covers the 2.0 T-series) which I may be able to scan at some point.
- BlueRover
Conversely, my 820 Haynes covers the M and T in detail but the bodywork seems to be Mk1 oriented.TheVDM wrote: Edit: I also have the Haynes 820 workshop manual which is a little different to the service manual (it only covers the 2.0 T-series) which I may be able to scan at some point.
- TheVDM
Oops, I missed that bit out, it does also cover the M-Series, although it doesnt cover the T-Series coil packs, only the distributor.BlueRover wrote:Conversely, my 820 Haynes covers the M and T in detail but the bodywork seems to be Mk1 oriented.
- whitelion58
Thanks again to Jim for providing a stack of new material. All uploaded to the Manual section we now have:
Overhaul Manuals:
Rover 800 Workshop Manual Version 2 (1996)
T-Series Overhaul Manual
KV6 Overhaul Manual
PG1 Overhaul Manual
T750 Overhaul Manual
Electrical:
Electrical RHD
Electircal LHD
In Car Entertainment:
I.C.E R660, R770, R860
I.C.E R960
Owners Handbooks:
Handbook RHD
Handbook LHD
Checklists:
Maintenance Checklist
Pre Delivery Inspection
Dealer Checklist
Other:
Repair Operation Times
Paint Finishing Times
TestBook User Manual
European On-Board Diagnostics
Enjoy.
Tim
Overhaul Manuals:
KV6 Overhaul Manual
PG1 Overhaul Manual
Electrical:
Electrical RHD
Electircal LHD
I.C.E R960
Owners Handbooks:
Handbook RHD
Handbook LHD
Checklists:
Dealer Checklist
Other:
Enjoy.
Tim
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
- TheVDM
Not a problem at all, hopefully some of the manuals will come in handy to others on here.
- Joined: Wed Jun 05, 2013 2:30 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Im getting a 404 error when trying to view the MK1 section... Is it down currently? In fact mk2 section also shows 404 error, file not found.
I'm getting the same message for both these sectionsdecalservice wrote:Im getting a 404 error when trying to view the MK1 section... Is it down currently? In fact mk2 section also shows 404 error, file not found.
- TheVDM
If it's down I'm pretty sure I have a copy of all the MKII manuals on my computer if that's any help? Unfortunately I don't have a copy off the MKI manuals, but I do have a PDF of the haynes manual and a paper copy of the official MKI Rover manual that I could photocopy a few pages of.
Charles I have all the manuals downloaded onto my pc in pdf in case this happened let me know your email address through a PM and i will send the copy you need
Thanks Steve - I sent you my e address in an email because the pm service seemed to be down.
Just checked my emails charles and nothing there?Charles827si wrote:Thanks Steve - I sent you my e address in an email because the pm service seemed to be down.
