Vard's Volvo
- Vard66
Vard's Volvo
Taken the day after she was delivered.
Swapped side repeaters and rear lights for clear V70 items, fitted Pro Sport Coilovers.
1996 manual Volvo 850 R Estate.
I've always loved the 850 estate, since seeing them in the BTCC when very young. Couple that with loving the noise and power of the T5 and it had to be done at some point.
Back in November I was having a casual look at T5s and T5-R's on eBay, with no real intention of buying one, until Lloyd popped up and told me he had an Olive Green Metallic '96 850R estate that needed some work for the MOT (handbrake cables, tyres and stopping the front wheels rubbing at lock) and a VIC check as it had been written off, but bought back by the owner, and had a new driver's door and wing put on.
I went and had a look, the car was sound, the respray job is reasonable and the price was right for a manual R estate in a rare colour, so I splashed. Lloyd very helpfully delivered the car to my door that evening.
It's taken me since November to get the funds together to get her sorted and back on the road; thoughts the mechanicals were sorted for the MOT (which was a bit of a farce) a while before now.
Plans for now are tidying her up and sorting out a couple of things that need doing; the suspension I sorted this weekend just gone with a set of Pro Sport coilovers, as the Spax springs on her made her ride like a waterbed.
Long term plans include a V70R turbocharger, full stainless exhaust, full induction, boost control and venting and a remap to somewhere between 300 and 350hp.
Parts I've replaced since owning her -
//2013 - Handbrake cables
//2013 -
//2013 -
//2013 -
//2013 -
//2013 -
//2013 -
//2013 -
General maintenance -
Planned maintenace -
Flush and bleed brake fluid,
Wash her to within an inch of her life and remove all the crap on her paintwork,
Replace fuel filter,
Oil change,
Gearbox oil change,
Replace smashed to crap R bumper valence with standard 850 item while I repair the R one,
Touch up rear window demister lines,
Replace manual O/S mirror with electric,
Replace PCV,
Current modifications since my ownership -
??/01/2013 - Monstrous 900CCA BMW 530D battery,
12/04/2013 - HKS cone filter,
14/12/2012 - 5mm wheel spacers fitted to the fronts,
05/01/2013 - V70 clear rear lights & side repeaters,
13/04/2013 - Pro Sport height adjustable coilovers,
Rubber of choice -
Planned modifications -
Of which;
- are in my possession and waiting to be fitted -
- have been ordered -
- are yet to be acquired - back box deletion, replaced with 2.5" stainless sleeved straight pipe,
- IPD front strut top brace & lower front strut brace, rear strut brace,
- IPD silicon 8.5mm ignition leads,
- Silicon boost hose bends
- Mikalor W4 Supra clamps on every boost pipe join,
- Projector lenses and HIDs (?)
- TD04HL-19T compressor housing & cartridge,
- Euro Sport heat shield,
- A'PEXi Power Intake filter,
- Twin piston dump valve,
Emissions results -
- Fast Idle Test -
CO2 (%vol):
Lambda: [/quote][/quote]
Vard.
2004 Astra SXi 1.7 CDTi
1995 Land Rover Discovery 3.9 V8i
______________________________________________________________________
- Location: Warrington, Cheshire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Vard's Volvo
Very nice choice ..... best 'sleeper' there ever was ..... Even the Vitesse carries clues as to it's potential speed but the T5's never really did.
Re: Vard's Volvo
Get it chipped.
It makes a huge difference IMO, I sold off the standard T5s I had. Compared to my R I found them quite boring TBH. Without any mods they're just too quiet.
I was lucky though as I bought mine done. A big chunk of cash to lay out otherwise.
- Vard66
Re: Vard's Volvo
A remap is in the long term cards for her, Chris. Gonna get her to 'stage 0' if you will first, PCV and a couple of other things, then breathing - that huge collector box in the rear section has GOT to go.
It's not terribly dear from what I gather, 300-350hp is achievable under 1500.
Good exhaust, good induction ~500 19T from a V70R ~300 silicon hoses at the bends with good bolt clamps ~200 boost management ~100 and remap to anywhere between those two figures ~150, maybe an intercooler and reversed boost pipe kit if aiming for 350hp, standard intercooler is reportedly pretty happy with 300hp. Apparently no need to mess with fuelling or internals until you're staring down 400 odd, which is further than I want to take her anyway.
Incidentally, have you found a UK Volvo forum you're happy with yet? I'm having trouble finding one that seems welcoming or well run, and I'm having problems logging into volvoforums.org.uk at the moment, keep getting an Incorrect Redirect URL after entering my username/password.
Vard.
Re: Vard's Volvo
Maybe I'm just tight?
I only paid £930 for my car with the remap already done.
Mine needs the PCV doing as well. Have the bits, just haven't found the time/interest.
Mine is more than capable so I have no plans to touch it TBH, though if I had a criticism it would be I would like more low down grunt. My pet hate of turbo engines.
Oh and grip in the wet. Mine's that bad when trying to drive it quickly it's been parked up over the winter.
Volvoforums is the only one I've been on, though TBH I've not been doing much foruming at all. I went quiet on here due to too much else going on. So I didn't look for a replacement if that makes sense? I've only looked in when I've needed info not to take part as such.
- Vard66
Re: Vard's Volvo
Aye, I can't blame you there.
Not thought about looking for an AWD R? Was a gorgeous black one and a gorgeous Saffron one on eBay at the same time a couple of weeks ago. Do love Saffron.
Bloody bargain at that price for an R tbh. Have you investigated the diaphragm in the recirc? Reportedly if the diaphragm is split it can cause a lack of boost development at lower RPM's - something else I think I need to do on mine as she only really seems to go hard after 4k, and there's rather a lot of airy noise under low rpm throttle.
Vard.
Re: Vard's Volvo
I've looked a few times. Seen a lot with the rear disconnected though.
It was cheap, right place at the right time I guess?
I've hardly touched it TBH, I may look into later on.
- Vard66
Re: Vard's Volvo
Aye, it's quite common apparently, the planet gears in the diff don't like the torque, and tend to strip, so people simply disconnect the prop, much like with the Freelanders.
Not a terrible job to replace them by all accounts, but the gears themselves are rather dear, though a lot of dealerships carry them in stock.
Vard.
Re: Vard's Volvo
Do they have a proper centre diff? I was wondering because the Calibra 4x4 used to trash its 4WD system if the tyres were not identical sizes at all four corners - and needed to be rotated around the car to allow for wear.Vard66 wrote:Aye, it's quite common apparently, the planet gears in the diff don't like the torque, and tend to strip, so people simply disconnect the prop, much like with the Freelanders.
Re: Vard's Volvo
I'm sure it's not but I don't have the interest at the minute.Vard66 wrote:Aye, it's quite common apparently, the planet gears in the diff don't like the torque, and tend to strip, so people simply disconnect the prop, much like with the Freelanders.
Re: Vard's Volvo
Another 800 owner getting a Volvo! Nice find there Vard, bit of a bargain from what i can work out!
You've found the volvo forum that seems to be the most helpful/informative and the login problems have been solved as far as i know - i don't have any trouble logging in anyway!
Something that might interest you is there's a lad on there fitting the T5 engine to a 1988 245GLT and modifying the engine as he goes. The thread runs to something like 60 pages, nice bit of bedtime reading for you!
- Vard66
Re: Vard's Volvo
Antz, the fella up in Huddersfield?
Wonderful looking machine that. Also worthy of note that he's using Vitesse Recaros.
Vard.
Re: Vard's Volvo
Got him in one - wondered if you'd seen the bit about the Vitesse Recaros! He's got very little left to do to finish it now but it's all fund-consuming stuff from what i gather.
Would love to do something similar to my 740 but just can't these days, regardless of cost. Can't wait to see Antz "255" finished though, it's certainly going to an awesome sleeper!
