Vm into Triumph2000
Non-Rover chat and tech stuff
bribull
Newbie
Vm into Triumph2000
Post by bribull » Sun Nov 24, 2013 8:35 pm
In response to a request for pictures.
Progress so far, engine mated to a 4hp22 automatic gearbox with range rover bell housing and torque convertor, engine and gearbox mounts done. Inlet, exhaust manifolds and sump from the ford scorpio Vm (north south configuration).
Working on electrics now. Some success, still figuring out ccu/immobilliser wiring. I need to be able to simulate entering eka code should the remote decide to die on me. Can lock and unlock, and alarm led does what it should but not sure if immobiliser is being disabled. Will find out when I try to start it !!
http://s690.photobucket.com/user/oilybr ... %20Triumph
Brian
Triumph 2000/825 diesel saloon (I'm working on it)
3.5 discovery v8... daily driver
Triumph stag(nearly there)
Bmw 2.5td series 3... daily driver
Re: Vm into Triumph2000
Post by scoobyh123 » Sat Jan 18, 2014 7:15 pm
Found your thread Brian! I've sort of explained the process (in the other thread about the immobiliser) of using photobucket to get pictures on here but basically if you do one photo at a time and use the IMG code (just click the code on photobucket to copy it) then paste it here, you should be able to get individual pictures.
Here's one i tried earlier :
Don't want to steal your thunder doing them with the appropriate words etc but that one looks like the VM engine in the Triumph engine bay i think?
Hope that's useful for you!
Post by Richard Moss » Sat Jan 18, 2014 7:33 pm
You've done some work there
bribull
Newbie
Post by bribull » Sat Jan 18, 2014 9:04 pm
Just trying out picture posting
Engine and gearbox removed and just going in for surgery
bribull
Newbie
Post by bribull » Sat Jan 18, 2014 9:06 pm
Thanks for the picture posting help Dave :-)
Post by scoobyh123 » Sat Jan 18, 2014 10:27 pm
You're very welcome Brian! :D
