1997 SLK 230 Kompressor
Re: 1997 SLK 230 Kompressor
The car itself has kind of done the rounds - I don't doubt at some point someone has struggled with it, but also it's not the kind of thing you'd sell the car on for. It's annoying, but it's not a "quick, stick some K-Seal in a hope the head gasket holds" kind of thing
That points to an ECU fault then or as it's described in the link i posted, PCM - Powertrain Command Module which is USA-speak for ECU so this is beginning to make some more sense now.
What about a secondhand ECU? If you can get the Bosch number off it (usually they start 0 280 xxx yyy but later stuff uses a different prefix number as they ran out of 0 280 [fuel group] options) you could search for that number on fleabay and maybe find another.
Be careful to pull all the fuses that feed the ECU and disconnect the battery before changing the ECU though and once changed, reconnect the battery followed by the fuses. This is more to protect the ECU than anything else as some Bosch ones are susceptible to voltage transients when disconnected or reconnected "live".
Before you try to start it, read and clear the fault codes in the replacement ECU so you know you're starting with a clean sheet.
Mainly because I'm not yet able to confirm that it is indeed the ECU at fault. It could still be the K40 module, it could be...almost anything.
I'm happy to replace parts, but only when I know they are the fault. If the MOSFET replacement didn't work, it's hard to justify replacing the whole ECU unless I can confirm that it's the root cause
This is mostly why I want to do away with the electromagnetic clutch altogether - the facelift versions did exactly that and just had a permanently driven pulley. The switch would be nice to retain control, hence the button-switch I'd like to install.
If later models had a permanently driven pulley on the supercharger, i have no idea why it was specified under ECU control originally, no gains to be had really except maybe at idle for the emissions.
I'll hopefully stay more awake tonight and draw out that diagram for you.
Thanks Dave - and don't worry, I think I was overthinking it (as per usual...)
https://www.pinterest.co.uk/pin/40954677847249569/
This will do it. It's only the integreted LED that was throwing me, but that's just a single wire, and an additonal loop on the switch itself
That was actually the circuit i was trying to think of Adrian but had a mental block on it as well. Also falked on the sofa in a very strange position last night.
Looking at the circuit, you can feed the switch from a power supply that is live once the key is turned (it could be almost anything) and leave the switch in the ON position at all times, unless you actually want to switch the clutch off.
