Re: 1994 BRG Vitesse Fastback
820Vitesse
Post by 820Vitesse » Thu Jan 09, 2020 11:30 am
I agree Marc, I put the car in some shows last summer for the first time. I spent a lot of time cleaning and preparing the car and found so many small scratches, dents and imperfections, once you fix one and step back to admire your work another leaps out at you. I want to get the whole car repainted so it is like new when I am happy with the mechanical side so could be a couple of years till then.
If you come to the UK again with your car and mine is on the road we must find a way to get them together for some photos
Post by scoobyh123 » Thu Jan 09, 2020 12:47 pm
820Vitesse wrote:
Thu Jan 09, 2020 11:20 am
Dave thanks for the comprehensive post, very useful, I will only carefully remove the loose stuff not apply any force, anything I remove will not be any use in the process you describe.
I had a brief look at the video online of a chap makes one using Land Rover parts I suspect this is something I will have to try, I sort of want to so it is top condition rather than repaired, this weekend I will know more but my daily needs some overdue attention too so I may be on that instead unfortunately.
To be honest Jim, i wouldn't even remove the loose stuff, i've found it usually works its way back into good metal and if not, it comes off by itself.
I think the guy who did that video also sells them on ebay for about £170 and is also a forum member. If you do choose to make your own, you could simplify the design by making the filler neck in the same diameter tube all the way along, instead of having the larger end at the cap end. As long as you have a cap that fits and can get an unleaded pump nozzle in, you should be ok.
Alternatively, buy an aftermarket filler and link the two with fuel hose.
https://www.carbuilder.com/uk/fuel-caps ... orderBy=10
A few options there! I used something similar to this for my Coupe but this one has the vent already on the side :
http://www.solentmarine.co.uk/acatalog/ ... iller.html
It's stainless as well so matches much of your other work. If memory erves correctly (which it may not this time) the lower link hose from the filler neck to the tank is about 38mm/1.5" so this would be an almost direct fit plumbing wise.
820Vitesse
Post by 820Vitesse » Thu Jan 09, 2020 9:11 pm
Oh no why did you show me all that shiney stuff, now Im thinking about fabricating something from scratch.
The metal parts I have been waiting for turned up today so I have plenty to get on with while I work out what to do about the fuel filler.
Steel, stainless steel and aluminium plates
Adding more precise camber adjustment to the rear suspension turrets
A steel plate for the fuel filler pipe if it is repairable
An aluminium disc adapter for Astrali boss to OMP wheel
Steel plates for the gearbox mount
Biggest and most frustrating problem now is getting time on the car.
Post by scoobyh123 » Thu Jan 09, 2020 11:58 pm
The shiny stuff might be easier! :P
Use your steel flange that you have for the filler neck to mount a new filler in then some thin wall flexible fuel hose to connect to the tank or at least to the bottom half of the OE filler neck (the bottom half never seems to rot for some unknown reason!) then sort something out for your vapour control loops and the tank breather/vent and job done.
Post by Marc-827-Vitesse » Sun Jan 12, 2020 1:33 pm
Exactly that! And yes we must find a way one i come over! Looking foreward to it. :)
820Vitesse
Post by 820Vitesse » Wed Jan 22, 2020 9:39 pm
Agreed, looking forward to it too. I just need to put my car back together now but with the new parts already mentioned and lots of bolts back from plating things should speed up a little.
Spare starter motor painted and ready to fit
Re-painted some brackets and mount parts before reassembling
Steering wheel adapter disc drilled and tapped (mislaid one of the countersunk screws) waiting for a 30mm spacer then I can fit the boss and wheel to the car and sort the horn wiring.
Started on the gearbox mount, cut off the part no longer needed and made a little wooded jig.
Look away Dave. The fuel filler pipe I cut the vent pipes off at the brackets to make access easier for removing paint and rust, I can weld them back if the repairs are successful. So far it is still water tight but but has some nasty pitting. I have ordered Bilt Hamber Hydrate 80 for when the worst of the loose stuff is removed.
Still plenty to do on this but really do not want to make one from scratch unless I have to
Post by scoobyh123 » Wed Jan 22, 2020 11:48 pm
More good work there Jim and i have to say, i'm pleasantly surprised at the overall condition of the fuel filler!
Reckon you got away with the abrasive cleaning method! Have you leak checked it since cleaning it?
You know what i'm going to suggest though, give it a night in the electrolytic cleaning tank, just to reinforce the metal or give it a coating of rust converter followed by etch primer and if you can find one, a resin based top coat.
Once done, weld the vapour loops onto a pair of Jubilee clips and use them to secure the vapour loops to the main filler neck so you don't heat-damage the resin paint.
I'm sure you have a few ideas in mind as well, perhaps even clear passivate them like you've done the bolts. Looking forward to the progress on it either way! :wink: :D
820Vitesse
Post by 820Vitesse » Fri Jan 24, 2020 10:48 pm
Thanks Dave, I will leak test it again this weekend as I have been working on it last couple of evenings so hope it is still ok.
820Vitesse
Post by 820Vitesse » Mon Jan 27, 2020 8:47 pm
Filler neck progress, cleaned the rust back further, cut the rusty flange off and leak tested it just with water but luckily so far it is ok. Then gave it a coat of Hydrate 80 up to where it will be welded.
Users browsing this forum: No registered users and 7 guests
