Re: 1994 BRG Vitesse Fastback
Nice work as always!
- Kyle
- Location: Manchester [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
How did you clean up the filler neck ? grinding disc?
2000 Audi TT 1.8T 225 Quattro Silver.
1996 Rover Vitesse Coupe - the new towcar
- 820Vitesse
Bit late but thanks Marc
By hand, starting with 40 grit emery cloth, I cut the vent pipes off to make it easier then welded them back on once cleaned up, the top flange was beyond repair so welded on a new one, took bloody ages, would have bought a new one if good originals were available.
- Kyle
I think the spare neck I have needs a new top flange,820Vitesse wrote: ↑Wed Apr 07, 2021 10:22 am
how did you get the new flange on once you had made it up as surely the hole in the centre for the pipe won't be big enough to slide on from either end of the filler neck?
I think the flange may be too far gone for me to be able to use it as a template, do you know the dimensions of the flange?
- 820Vitesse
The pipe is the same diameter from top to flange, I cut round the flange weld leaving the welded part in place then welded the new piece it. see page 23 of this thread.
For the dimensions if I remember right it is symetrical but fairly simple. Tricky part was getting it rotated to the correct position for the studs/bolts before welding.
