My Coupe
- Joined: Wed May 15, 2013 8:17 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
My Coupe
Hi all
I am new to the forum and would like to say hello. I own a P reg 2.0 Coupe Sterling Auto. Got a few little things to do to it for MOT and hope to have it back on the road for summer.
- TheVDM
Re: My Coupe
Hi, welcome aboard. That's a nice looking coupe you have there, and one very awesome trailer too...
Good luck with the work for the MoT. That wouldn't happen to be at Manston would it?
Re: My Coupe
It's Caernarfon Airport, North Wales. Thanks for your comment.
Re: My Coupe
L-29 Delfin, I believe
Re: My Coupe
Yes, L29 quality built Russian aircraft, flew into Caernarfon airport and stood outside for years. The photo's were taken just after it was dismantled and the rover dragged it out with a seized caliper on L29, a bit heavy. L29 is now down south somewhere being put back to flying condition as part of L29 display team.
Re: My Coupe
like both of these, welcome to the forum and good luck with the mot
Re: My Coupe
That is a great sight, but where are you taking the aircraft? I'd say that trailer even beats the one Chris chopped up.
- TheVDM
Re: My Coupe
Would that be the one that was made out of the rear end of another 800?Manalishi wrote:I'd say that trailer even beats the one Chris chopped up.
Re: My Coupe
Correct!TheVDM wrote:Would that be the one that was made out of the rear end of another 800?Manalishi wrote:I'd say that trailer even beats the one Chris chopped up.
Re: My Coupe
Is there a photo of the trailer on the forum?
- TheVDM
Re: My Coupe
Hi, the pictures can be found here http://www.rover800.info/forum/viewtopic.php?p=82677
Re: My Coupe
Being picky it's Czech Which actually usually means much better quality engineering than Russian stuffpauleilio wrote: L29 quality built Russian aircraft
Re: My Coupe
Hi,
Can anyone help me? can't open drivers door after unlocking. This happened on another rover 800 saloon I had many years ago and I failed to repair that without damaging the door card. Has this happened to anyone else on the forum and maybe found an easy way around it? Any help would be hugely appreciated.
Many thanks
Paul
Many thanks
Paul
- simon
Re: My Coupe
can you open the door from inside?
Simon & Jane.
Rover 825sd 229,000.
2 rover 75's
2 rover 75's
Re: My Coupe
No, it's like it's in superlock, when I unlock it with the keyfob the button only goes up a little and then will lock itself again, same with the key. I have manged to lift the button whilst unlocking with the keyfob and the car remains unlocked but neither outside or inside handle will open the door. Like your photo of the rover in snow.
