Simon's 827 Coupe
Re: Simon's 827 Coupe
would'nt it be better to replace the whole dash as once glued down you will be buggered if you need to get the aircon switch pack and bulbs etc.
I have removed the instrument dials and facia pods (if that is what they called!) so it can all be glued down. I will post some pictures when I get round to doing it.rovercoup wrote:would'nt it be better to replace the whole dash as once glued down you will be buggered if you need to get the aircon switch pack and bulbs etc.
As Simon says, if you remove the instruments and switch panels first then there is no problemrovercoup wrote:would'nt it be better to replace the whole dash as once glued down you will be buggered if you need to get the aircon switch pack and bulbs etc.
Having moved house recently work has been a rather slow on any of our cars, but I have sorted (hopefully) the dash lift. It was very bad, but had not been messed around with previously.
Some before...
During...
And after shots...
This shot does not look great, but once everything is screwed together I think it will be okay.
Once all the instruments and switchgear is replaced I will post some more pictures. Thanks for looking.
Some before...
During...
And after shots...
Good work there, it was so bad it almost distorted out of proportion! I must say I am surprised how Rover could fail so badly in this detail. My dash lifts a bit every summer and I need to glue it down at least once a year.
Here is the dash all put back together. It is not perfect, but considering how awful it was when I started, it is not bad.
- TDHFastback
- Moderator
Cripes what a difference.
Good work there Simon it looks a million times better.
Kate
Kate
Thanks for the comments, it is much appreciated and spurs you on.
It's a naff job to get right. Fiddly and messy if you aren't careful. And for taller drivers like you, not much room to work in with long arms and your knees up by your chin. Definitely a smaller person can do these interior tasks more easily.
well done on the dash Simon, looks great
That looks perfectly reasonable - nice work
Users browsing this forum: No registered users and 40 guests
