tonewheeldude
Post
by tonewheeldude » Sat Dec 17, 2016 5:56 pm
SJG wrote:Lovely pictures, we took the Vitesse to Dorset and towed the caravan with it in August. Had a wonderful holiday.
Its certainly a lovely part of the country and get down there whenever possible. We sold the Dandy (1968 folding camper) in the photos once we got home and went back to a caravan. We thought long and hard about what to get as it had to look right with the Rover. Ended up buying three Castletons! (long story) but settled on a 1980s Castleton Roamer that had been completely stripped. Managed to restore it and get a week away in it before the cold weather set in.
What caravan do you tow with the Rover?
Post
by SJG » Sat Dec 17, 2016 8:06 pm
We have a 1999 Elddis van, so appropriately aged to the car. It is easy to tow and fully laden is around 1100kgs. We had a folding camper also, but as we enjoyed using it so much we wanted to get away out of season too, hence getting the van.
Post
by scoobyh123 » Sat Dec 17, 2016 10:09 pm
tonewheeldude wrote:The location is just east of Kimmeridge. Between Lulworth and Corfe Castle. It is an amazing stretch of coastline and if you enjoy walking the coastal path is breathtaking.....quite literally at times.
There were loads of those pumps on eBay at the time and a fraction of the cost of the 800 pump. I did not need the extension tube, you could be right, if its for the rear it might be a valve.
You can access the pump without taking the bumper off, there is a plastic cover that unscrews directly under the bottle giving access to the pump. Trouble is, when you pull the old pump out you are obviously under it....and you have to move fast to avoid getting wet
That explains the stunning scenery then!
Had a look on ebay, found a few and watching one now, thanks.
As the bumper has to come off for other things, i'll do all the jobs at the same time. It hasn't looked right with a gold top on the bumper but better than a square corner! I have the satin black ( i know it's 40% gloss Stevee) which will have to be close enough.
The countryside is amazing down that part of the world Simon, better than the flatlands of East Anglia for sure!
All auto
Post
by SJG » Sat Dec 17, 2016 10:49 pm
Our family have holidayed on the isle of perbeck for over 40 years, it is one of our favourite spots in the UK, or the world. However I must say we've also enjoyed some lovely visits to the East of the country Dave.
Post
by scoobyh123 » Sat Dec 17, 2016 11:10 pm
I suppose when you live in a particular area familiarity breeds contempt, that said when so much of it is just flat and wide open it's difficult to see the beauty in it. Especially on a day like today where one fog-bound flat road looked very much the same as the next.
All auto
tonewheeldude
Post
by tonewheeldude » Sat Dec 17, 2016 11:11 pm
FlashGordon
- Location: Galliae Cisalpinae, oram fluminis septentrionalem Rubiconem.
Post
by FlashGordon » Wed Apr 26, 2017 10:08 am
FlashGordon wrote:
Original seal is 19 x 12 x 5 mm,
will try this 19,2 x 11,2 x 5 mm ... maybe it fit
Fit on slave of my Rover 825 SD this seal from mercedes cluch master cylinder kit 19mm, it work perfect for now.
http://www.ebay.co.uk/itm/AUTOFREN-SEIN ... SwiDFYMwql
Flash
FlashGordon
Post
by FlashGordon » Sat May 13, 2017 8:33 am
tonewheeldude wrote:So the Coupe is back. And what a difference! Silky smooth action and the pedal is at normal height. It has transformed the car as there was slight judder (probably due to the slight leak on the oil seal), slipping and poor pedal action.
The clutch was down to the rivets and the garage picked up on the other problem mentioned a while back; the very low pedal. They explained one of the bolts holding the Master cylinder in place was missing and is virtually inaccessible. Probably because it requires removing quite a few components to get to it. This meant over time the master cylinder was moving away from the bulkhead - every time the clutch was depressed the whole thing would move, bending the bulkhead at the fitted bolt...hence the very low travel. They replaced the bolt and pedal is as it should be.
The total invoice was for £250 including the crankshaft oil seal. Add that to the genuine clutch kit I picked up on ebay means the whole thing is £20 short of £300. tomorrow I will be giving it a 300 mile test drive...can hardly wait!
edit: Sorry Dave forgot to reply to your post. Not sure what to think. Basically I took the original part number and cross referenced it against several other compatible parts:
Oil seal part number (LUF100500) from here:
http://www.rimmerbros.co.uk/Item--i-GRID004811
Compatible part numbers
FORD 1054053
JEEP 5010817AA
RENAULT 5000684700
AJUSA 15041700
FAI AutoParts OS515
PAYEN NF837
ELRING 225.666
CORTECO 20029786B
OS515 is allegedly used on loads of Suzuki's of all engine sizes.
Very interesting, notice also about compatible o-ring GUG705649GM ?
Flash
deano
Post
by deano » Sat May 13, 2017 4:41 pm
Going back off topic for a mo...
Always loved the look of Lulworth Cove but never actually visited it, even when holidaying in the area.
So about 2 years ago we made a special detour on our way back from Devon to see it.
TBH I was somewhat disappointed , it's all a bit rough when you get there , not Sandy at all.
More like Shingle .
Still love the area though , anywhere Devon , Dorset , Cornwall , Somerset etc
tonewheeldude
Post
by tonewheeldude » Fri Jun 16, 2017 2:28 pm
Lulworth Cove is nice for a walk, and if you had a litle boat would be lovely, but its not a beach you would want to spend any time on, unless you enjoy geology, in which case there is enough to keep you bust for a whole weekend. However you can walk from Lulworth to Durdle Door - very worth while doing. The sea is clear and a pleasure to swim in at Man O War Bay, there is some sand and some shingle, but the views more than make up for the shingle. I am much happier just staying in Purbeck though.
We were supposed to be going down this weekend but the Rover has failed on power steering leak so. Have a brand new genuine rack to fit, but am struggling to sort the pipes out.
Post
by scoobyh123 » Fri Jun 16, 2017 6:09 pm
Which pipes are you in need of Darren? Dusan is breaking his Vitesse following an engine failure, i know the racks are the same but not sure on the PAS hoses.
All auto
tonewheeldude
Post
by tonewheeldude » Sat Jun 17, 2017 7:54 pm
its the cooler and the return hose from the rack to the cooler. Mine is still intact, but i dont think it will stand much moving about. I have ordered a new cooler (for a series one), not sure if it will fit but might be able to modify it, but they are fairly inexpensive and I imagine all the used ones are going to be nearly finished.
tonewheeldude
Post
by tonewheeldude » Sat Jun 17, 2017 7:59 pm
Post
by scoobyh123 » Sat Jun 17, 2017 10:20 pm
tonewheeldude wrote:its the cooler and the return hose from the rack to the cooler. Mine is still intact, but i dont think it will stand much moving about. I have ordered a new cooler (for a series one), not sure if it will fit but might be able to modify it, but they are fairly inexpensive and I imagine all the used ones are going to be nearly finished.
As far as i'm aware the PAS fluid coolers are the same across the range through all the years Darren and many people have made their own using 10mm flexible copper pipe. Others have used 15mm household plumbing pipe with 15-10mm reducers on each end to connect the hoses.
All auto
tonewheeldude
Post
by tonewheeldude » Thu Jun 22, 2017 6:46 pm
This was the cooler I bought:
http://mgrovergenuine.co.uk/genuine-mg- ... pas-fluid/
Its a genuine part and listed for a Series One 2.0l petrol and diesel. But it fitted fine on my 1999 diesel and now with the new rack, fluid and tracking feels much more positive on the steering and I am not worried about it bursting.
Note the cost of he cooler: £29.46 !! (delivery was £5 on top of that for me) If you have a rusty cooler this seems like a good option.
[phpBB Debug] PHP Warning: in file
[ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line
1266:
count(): Parameter must be an array or an object that implements Countable
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 19 guests
