- tonewheeldude
After Repair:
WP_20151112_14_07_15_Pro by T_W_D, on Flickr
repaired area nearest bottom of photo
And tracking - suprisingly not agreat dealout, just tweeking on the front and rear N/S:
WP_20151112_15_29_17_Pro by T_W_D, on Flickr
is that a rover badge hanging down underneath the rear bumper ?
- tonewheeldude
I have to tow a trailer sometimes, and not wanting to spoil the look of the coupe searched for a genuine towbar kit, I was fortunate enough to find one last year and a few weeks ago came across a brand new set of Rover electrics (so no cutting into the wiring). The 13pin trailer plug has a Rover badge on it and to protect it I bought a rubber cover and put a Rover badge on that too - which is what you are seeing. The tow hook is removeable and not on the car in the photo.
Oops! Painful! If that doesn't cure the wheels, there's a KV6 saloon with some nice 15" alloys being broken :
viewtopic.php?f=15&t=13547&p=136361#p136361
- tonewheeldude
Thanks Dave, I went to the NEC in it this weekend and it all seems fine now. That V reg saloon looks too nice to break.
It does but it was up for sale on here for ages and then ebay at least once.
Glad you got the wheel sorted out and the tracking etc and no other damage!
- FlashGordon
- Location: Galliae Cisalpinae, oram fluminis septentrionalem Rubiconem. [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Found some rubbers similar at last?tonewheeldude wrote:Hi Dave - thanks, although these are slave cylinders and seal kits for a standard petrol 800 - the slave cylinder is completely different on the diesel:scoobyh123 wrote:Slave cylinder repair kit on fleabay :
http://www.ebay.co.uk/itm/Reparatursatz ... 5424d4e01b
For reference the OE part number is CDU2331EVA and the listing has a few more OE numbers as it turns out to be the same seal kit used in some Marinas, Saabs and Allegros. They also list a new cylinder for about £35 + P&P but they list it for many other 800s including petrol and the 820/620 turbo. The turbo versions may be another possibility but as i expect you've found, the diesel uses a unique slave cylinder.
http://www.ebay.co.uk/itm/Kupplungsnehm ... 5d5d7c923c
I started out by looking for Jeep Cherokee 2.5TD and Alfa 156 TD slave cylinders as both of them use the same VM engine. However not much seemed to correlate.
Not sure if any of that is any help or whether you've already been down that route of looking for alternative vehicles.
and the seal (17mm) is the wrong size for my car which is 19mm.
Absolutely! As much as getting to know new folk is great - I was not relishing the idea of spending most of the day in a truck with a recovery chap, plus it made it easier getting my wifes family home too.mercedade wrote:That's a great result - congratulations! Must have been a massive relief too.
Must rebuild clutch slave cylinder in my 825 diesel but very hard find seals
This one maybe? :
http://www.ebay.co.uk/itm/DISCOVERY-1-R ... 1119067665
Flash
I think after Darrens recent experience with clutch slave cylinders he's now the "go to" expert on them so i'll let him answer that one!
- tonewheeldude
Thanks Dave - not by choice I assure you!
the 514244 lockhead kit fits a number of vehicles and cross references to lots of other manufacturers, but I couldn't seem to find the diameter (although it might be 22.2mm) - the 825 dieselseal needs to be 19mm. There must be another slave cylinder with the same bore...thats what we are looking for. - I will keep on the look out too.
My seals came out of a Land Rover wheel cylinder I think.
- FlashGordon
Someone try if seal of this kit fit?
http://www.ebay.co.uk/itm/ERT-300563-RE ... SwHQ9WXU9R
There is write:
Additional details of the part:
Diameter [mm] 19, Brake System BENDIX-BOSCH
There is write:
Flash
- tonewheeldude
its not expensive so I guess worth a try?FlashGordon wrote:Someone try if seal of this kit fit?
There is write:
tonewheeldude wrote:its not expensive so I guess worth a try?FlashGordon wrote:Someone try if seal of this kit fit?
There is write:
Go on - you know you want to! Have you got a dead slave cylinder or two that you could give it a try on? If it works then you can keep it in the boot as a spare in case the new one lets you down instead of having to wait a few days for recovery of you, the car and your passengers again.
- FlashGordon
This seal maybe?
http://www.ebay.co.uk/itm/Hydraulic-Cyl ... 1063297836
Flash
- FlashGordon
FlashGordon wrote:This seal maybe?
Original seal is 19 x 12 x 5 mm,
will try this 19,2 x 11,2 x 5 mm ... maybe it fit
Flash
- tonewheeldude
grrr, the Front pipe flexi is blowing. Was new last April!
