Kates D reg 1987 820Si Saloon
- Location: North Yorks [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Kates D reg 1987 820Si Saloon
That looks lovely i understand why you couldn't resist.
It couldn't be in better hands.
I do think the Mk1 has some elegant lines.
Glyn
Rubber Mats, not sure if they're Mk1 but they are definitely for the 800 series as they're too big to fit owt else!
Part # EAH10100 :
and 2 off EAH10101 with EAH10106 and EAH10107 :
Are these what you're after Kate? They could do with a clean but are in generally very good (almost unmarked) condition. In fact, if they were cleaned up the chances are they are unmarked as it looks like they've been barely used if at all. Having seen what you've done with the arches though, if anyone can get them black and shiny, i'm sure you can!
PS the drivers mat has been used underneath a carpet mat in my coupe, the carpet mat is falling apart hence the beige "dust" in the heel area but there is no obvious wear on it.
Seems although the mats have individual part numbers, they were sold as pairs under a "pair part number" :
http://www.rimmerbros.co.uk/Item--i-GRID004401
That lists the Mk1 accessories although it shows the mats as NLA. However, Allbrit.de do list them with prices!
http://www.allbrit.de/UNI.cfm?PAGE=657345&SPRACHE=EN
From their website :
Mat-front floor drop in
EAH10097LNF [ rubber - pair ]
replaced by:
EAH102260LNF [ ]
13.95 € /each - (EAH102260LNF)
0 - Mat-rear floor drop in
EAH10103LNF [ rear - rubber - pair ]
9.22 € /each - (EAH10103LNF)
Obviously in Euros and then there's the carriage from Germany...............assuming they have them!
The original accessories list makes interesting reading - i didn't know you could get a fridge for your 800 for example!
Part # EAH10100 :
replaced by:
EAH102260LNF [ ]
The first photo of your mats will fit either the earlier or later version with boot release on floor as it has the section to be cut away
- BennyVitesse
They just about fit a 100 too!
Ben
2001 Rover 75 Connoisseur CDT
2017 Nissan Leaf 30kW Tekna
rovercoup wrote:The first photo of your mats will fit either the earlier or later version with boot release on floor as it has the section to be cut away
That's what i was thinking. Since originally posting that i've done a bit more research and found some more information - including a possible source of brand spanking new ones!
- TDHFastback
- Moderator
Dave you have a PM
Kate
Kate
You have a reply Kate!
- TDHFastback
- Moderator
Found this old picture of the dealership the car would have come from. I'd have thought an inspection pit would have been easier for servicing
Kate
Kate
- vito
Wow look at that Metro Turbo behind, there's a scarce car now ...........
- Alex SBY
Very pleased this car (one of my old ones) remains with such a caring home. Love the 'sterling' work you've done on it so far.
Can't wait to get this shown alongside my immaculate 820SE...
One or two 800s...
Ah, Wadham Stringer, now there is a name from the past
- TDHFastback
- Moderator
Whilst doing a bit of theraputic cleaning last weekend I looked in the boot area and found a couple more early features.
The holding mechanism for the spare wheel is a little bit cruder than the later narled plastic device
Upon removing the jack set, its a little odd as the cellophane is unbroken, the jack unused but the tools are missing. I wonder if Rover forgot to put them in.
Anyone got a set? (Ha worth asking though)
Now more indulgent, unashamed pictures of the two on the drive
Sorry but I could look at them all day
Kate
Kate
Looking good Kate and I don't get tired of looking at your photo's neither.
In respect of the unused jack with tools missing, I would suspect that the original has been used or lost and replaced with the item that you have as it was only the cars with alloy wheels that didn't have the bit and pieces included as these were for removal of wheel trims or could have been purchased as a replacement from the dealer minus tools as a cheaper option?
I've spent most of the day looking at those pics too!
I could well be wrong but i think the only tool missing from there is the "L" shaped tool for removing the wheel trims. I don't think they ever actually supplied the extra tools as standard that the foam thing is designed to take.
This is EMP7157 which is superceded by 11H1051 and is common to the Mini and the Metro as well or for the grand price of £3.60 you could have a new one from Rimmers.
Alternatively i think i may have one around somewhere, i'll have a look.
