engine out
- Joined: Sat Nov 22, 2014 2:46 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
engine out
Hello.decided to take out the engine today as its wanting so many parts replacing I thought it would be easier that way
Boy is there alot of pipes and cables on these cars.I could not get a good enough grip on the power steering union on the pump so I had to cut it unfortunately, so I will be pricing up for a set of them soon.Please bare with me with the pictures as I am having trouble doing so
Re: engine out
If I can give you one piece of advice on working with 800s. Always check prices and availability of parts before starting. Sometime the most insignificant parts turn out to be NLA or prohibitively expensive.
There are some good threads on here giving alternative compatible parts that are cheaper or more readily available.
Re: engine out
Many thanks tom.I have been using rovaparts of Redditch for my parts so far and I have found he very reasonable and prompt,but I will now be checking on this site first from now on.regards james
Re: engine out
First of all, i'll reiterate what Tom said, avoid mutilating anything if at all possible! Don't forget you still have to do the job properly after and almost always cause yourself unnecessary extra expense - in some cases very considerable expense too! That's assuming you can get the bits. Much better to invest heavily in some WD40 or similar and a few sackfuls of patience and elbow grease. With rusted nuts, bolts etc don't keep winding the nuts off if they are getting stiffer. Wind them back on and squirt again with WD then try again. Each time should see the thread cleared further along until you can remove the fastener without damage.
Secondly, good luck with it all! Which car have you got?
Re: engine out
Good advice from Tom and Dave about saving as much of the original equipment as possible. Sometimes the most innocuous of parts can be the hardest to find and become a show stopper.
Re: engine out
Thanks for the posts and info.So far the worst thing that has happened was taking of the tie rod to control arm bolts.One was seized solid,no amount of heat,oil,scaffold bar extensions or patience worked so I had to then take of the arm and drill it out a different size step up at a time. (Note expensive drill bits are essential).Today though I have changed the cambelt using my tried and tested slice it in half method so I don't lose the timing at all. I know most purists wont agree with that method.pictures for this project are on the rover 800 Facebook page as I still cannot upload them here.cheers
Re: engine out
Sorry forgot to mention what it is, its a vitesse turbo saloon series 2, thanks
Re: engine out
Nowt wrong with that method, it's especially useful when the tech info is hard to come by on older vehicles. If you haven't already though, I would recommend changing the tensioner and spring at the same time.hare racer wrote:Thanks for the posts and info.So far the worst thing that has happened was taking of the tie rod to control arm bolts.One was seized solid,no amount of heat,oil,scaffold bar extensions or patience worked so I had to then take of the arm and drill it out a different size step up at a time. (Note expensive drill bits are essential).Today though I have changed the cambelt using my tried and tested slice it in half method so I don't lose the timing at all. I know most purists wont agree with that method.pictures for this project are on the rover 800 Facebook page as I still cannot upload them here.cheers
Re: engine out
Thanks tom,I will do that cheers,today I am going to change the gear rod linkages. (Hopefully)
Re: engine out
I managed to change the gear rod linkages today,it was a joy to do the only thing extra to do was put a wider washer on one of the heat shield bolts as it had broke through.
Re: engine out
After a long delay Xmas and work related I shall be refitting my serviced engine and second hand gearbox today,I can't wait.
Re: engine out
Great news - hope you manage to take some pics along the way
Re: engine out
I wish I could put pictures on this site its been a very frustrating experience as I just come to a dead end with every link I try.so I put my pictures on the Facebook page instead.Why can it not be easier to put images on this site.Anyway the engine and box is in only wrecking a new oil filter in the process, so not so bad.
Re: engine out
It is easy to put photos up - everyone else manages it! What "links" are you having trouble with?
Remember, this site does NOT host the photos themselves - they are hosted by Photobucket, Imageshack or whoever and you just copy and past the link they give you.
Re: engine out
The problem is that my laptop is nearly 10 years old and is knackered. It just won't do it and I can't afford another this side of Xmas. And my phone which is my preferred choice isnt capable enough to do it either, I have been told that I need a more powerful version but cannot upgrade until October. I will keep persevering though.
