Well done on your passes Steve and good luck for your coupe!
Re the advisories, i suspect the tester was unsure about the exact amount of play permitted on those items and as such was as suggested covering his ar5e.
Then again, some testers will only advise when something is near to needing repair - last year i had an advise on my N/S/F upper arm bushes. When i got home and checked, there was a fair bit of play present so i changed it for a good second hand one. However, the O/S/F upper arm bushes have now started making noise as well so i plan on turning some up from Nylon 66 for both upper arms and fitting them before the next test. Meanwhile something else on the front has started making a noise (and leaking ) so a new rack awaits my spanner-wielding! I have until May so i should just about get it done in time!
New MoT today. Yipee!
- rovercoup
Re: New MoT today. Yipee!
Thanks Dave and I am happy to tell all that the coupe also passed her test today with flying colours. Apart from it being cold January 2015 has been a good month, hope everyone else has had a good
one too.
one too.
- TDHFastback
- Moderator
Nice one Steve. Its always a relief when they pass. Look forward to seeing it sometime this year.
Kate
Kate
D reg Rover 820Si Saloon. No space for a a saloon in this rootin tootin town
G reg Rover 820SE Fastback (my every day runabout) that ran off.
G reg Rover 827Si police Fastback (last Mk1 jam sandwich)
V reg Rover 825 Sterling Fastback (end of an era)
