2.0 litre Sterling Coupe manual with cruise control
Re: 2.0 litre Sterling Coupe manual with cruise control
Yes a strange set of ratios. But nice if you don't push it and drive in a relaxed manner, I understand what you mean about the cruise control. I use it alot when we are driving Michelle's 75, so not at the moment!!
Thanks Kate, high praise from a lady whose cars are always immaculateTDHFastback wrote:That interior is lovely Dave and looks factory fitted. You are indeed a man of many skills.
Kate
Not wired up yet as I have a more pressing issue with cooling fans Any idea why Dusan couldn't get it too work??TheOldMan wrote:Dusan had a go at that too, with exactly the same parts.dollysprint wrote: Cruise system came from a 1996 420 GSi, switches are pure 800.
But he never got it to work.
Have you got your cruise running?
stanker wrote:Hi Davedollysprint wrote:Look at the engine bay picture above, just below the fancy blue oil filler cap you can see the thermostat housing with a connector on the front of it(thats the lambda connector leading down the exhaust manifold), between that connector and the small bore coolant pipe to the expansion tank you can just see the brass part of the CTS, coolant temperature sensor, just below that, but you cant see it in the pic is the temp gauge sender. Don't rule out the stat but I'd change the sender first.
The connector from the wiring harness to the CTS is broken, any ideas where I might be able to get some sort of replacement?
Regards
Ian
Hi Ian,
wrong Dave answering but from another Rover would be one option, failing that a good auto electrical place should be able to help (i don't mean the electrical section of Halfrauds either!) as they are fairly standard sort of plugs. If you can get a photo of it i'll have a look at the spares SLi in the garage and see if there's anything suitable, if so i'll post it out to you and you'll have to either fit it yourself or get someone to join the wires to fit it. Certainly seems to be the problem though!
There was a company that does all manner of Lucas Rist connectors but for the life of me I can't remember their name, either that or replace the engine loom. Thought you were more a v6/diesel man Ian rather than the 2 litre cars. Radio was a result though.stanker wrote:Hi Davedollysprint wrote:Look at the engine bay picture above, just below the fancy blue oil filler cap you can see the thermostat housing with a connector on the front of it(thats the lambda connector leading down the exhaust manifold), between that connector and the small bore coolant pipe to the expansion tank you can just see the brass part of the CTS, coolant temperature sensor, just below that, but you cant see it in the pic is the temp gauge sender. Don't rule out the stat but I'd change the sender first.
Regards
Ian
Was the fancy blue oil filler cap on it when you bought it or can you put a link up for them please Dave? I already have a nice, bright and shiny chromed filler cap on the Sterling but blue ones would go better with the theme i have (blue HT leads etc) so would be much appreciated!dollysprint wrote:Look at the engine bay picture above, just below the fancy blue oil filler cap
I remember driving the M42 in the Coupe with its infamous variable speed limits. It was limited to 40mph on this occasion and my Coupe used to change up to 4th at 52mph and drop down to 3rd at 44mph, so something like 3 junctions in 3rd gear!!That was just one of the times I thought Rover had just got it wrong and driving round town in 2nd gear because you couldn't get to the 3rd gear 30mph change point.Simon Hubbard wrote:Yes a strange set of ratios. But nice if you don't push it and drive in a relaxed manner, I understand what you mean about the cruise control. I use it alot when we are driving Michelle's 75, so not at the moment!!
I did enjoy the car as a relaxed auto but it some circumstances it just used to grind with me.
I got it off ebay a few years back Dave, it was on my Tomcat until last week. Still undecided as to whether I like it or not to be honestscoobyh123 wrote:Was the fancy blue oil filler cap on it when you bought it or can you put a link up for them please Dave? I already have a nice, bright and shiny chromed filler cap on the Sterling but blue ones would go better with the theme i have (blue HT leads etc) so would be much appreciated!dollysprint wrote:Look at the engine bay picture above, just below the fancy blue oil filler cap
Thanks Dave. You've had it a few years and not sure you like it??? Have to say i like my chrome one but first a blue one would go better with the blue Ferroflex leads :
and second, the one you see in the pic above is very tight to screw into the rocker cover - planning on "relieving" the thread slightly once i get my lathe up and running but until then it will do.
If i find a listing on fleabay for them i'll come back and post it up for anybody else who might be interested.
EDIT - found this nice Rover badged alloy billet cap :
http://www.ebay.co.uk/itm/Rover-Tomcat- ... 3aa003df4c
Dave search ebay for Honda oil filler cap, blue ones on there just leave the Mugen badge off!
Thanks Davedollysprint wrote:There was a company that does all manner of Lucas Rist connectors but for the life of me I can't remember their name, either that or replace the engine loom. Thought you were more a v6/diesel man Ian rather than the 2 litre cars. Radio was a result though.stanker wrote:Hi Davedollysprint wrote:Look at the engine bay picture above, just below the fancy blue oil filler cap you can see the thermostat housing with a connector on the front of it(thats the lambda connector leading down the exhaust manifold), between that connector and the small bore coolant pipe to the expansion tank you can just see the brass part of the CTS, coolant temperature sensor, just below that, but you cant see it in the pic is the temp gauge sender. Don't rule out the stat but I'd change the sender first.
Regards
Ian
This 2 litre saloon was on ebay, as pointed out by the other Dave, "nice looking car for anyone living in Wales" taxed, insured and mot'd, four new tyres, tow bar/ball hitch, same owner for the last 14 years, 95,000 on the clock, same gold colour as the 825, same black trim as the 827, original radio with cd changer in the boot, working drivers door window switch, working sunroof, rear seats in the same condition today, as the day they left the factory.
I was the only bidder, I was sure someone would jump in and outbid me, I didn't really want it, it was too far to go, it took all to drive there and back and cost another £60.00 in fuel.
Ian
Was that the gold 820 SLi Ian? Nice car indeed but the big problem was the distance and the fact it was manual (i think?) but glad it went to a good home
Yes Dave, that's the one, I had to have it, it's got a personalised number plate, well!, personalised to me, according to my neighbours.scoobyh123 wrote:Was that the gold 820 SLi Ian? Nice car indeed but the big problem was the distance and the fact it was manual (i think?) but glad it went to a good home
One of the rear passenger doors keeps locking itself, have you ever stripped a lock before?
Ian
Never did get the 420 cruise working, all wired up and no luck.
I had kv6 825 cruise as well which is identical part numbers on the ECU
I will say that in both cases of the donor systems neither were confirmed working before I started but the likelyhood of both being dead is slim to none.
I think either the speed signal is out of range or there was something I missed in the wiring. I dont have to time or apace at the moment to play around with anything but next time I have a crack at it I'll let you know
Love the non airbag dash on the coupe, after having the 827 with one going back into the 820 is annoying ! That shelf is so useful, usually my wallet from my back pocket goes there rather than sitting on it for a long journey.
Did you have the clutch and brake pedal switches wired in and did you take the speed signal from the instruments or from the gearbox speed sensor. Also can you remember where you wired into Mems?
