1995 N 827 Sterling
- Tenesmus
I decided the cost of refurb was too much. Anyway, I went over a particularly bumpy bit of road and I think a rear tyre came up and said hello to the arch. I guess it's the wallowy Sterling suspension, any suggestions?
Pete
7x17 is width and diameter.
Same as standard then. Tyres shouldn't be a problem either.
It could be that your rear end has gone soft.
- Tenesmus
Had new rear shocks a few months ago. Pattern Sterling, nothing special. All the tyres seem to be a little closer to the outside world compared to the 15s that were there before. I wonder if I need to get a bit creative with pliers and the inside of the arch?
Pete
Yes it's possible.
Looking the figures of your wheels they look to be very similar to the standard 17" ones. And they don't do that.
- Tenesmus
MOT time... failed on worn bushes, emissions, leaking front pipe, idle speed and a headlight bulb
Idle speed sorted by cleaning throttle body. Bushes no big deal, but pipe is a pain and they say a new cat is required (it does look very tired).
On an up note, they fitted new springs to the back and the wheels no longer seem to rub on the arches, although the acid test will be next week when my fat mate gets in the car.
Pete
Tenesmus wrote:On an up note, they fitted new springs to the back and the wheels no longer seem to rub on the arches, although the acid test will be next week when my fat mate gets in the car.
- Location: Cheam/Sutton [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Nice tidy looking car. Quite like those wheels on it as well. Aftermarket wheels usually look cr*p on 800s but those work pretty well......best colour scheme too
All the best
Rob
Rover 820 fastback (T reg) in metallic charcoal
Rover 420SLi saloon (K reg) in Ocean Blue (Gave up it's cylinder head to keep the 800 going....R.I.P)
Rover 820 Sterling auto (R reg) in Willow Green
Rob
Users browsing this forum: No registered users and 39 guests
