Re: 1994 BRG Vitesse Fastback
820Vitesse
Post by 820Vitesse » Sat Sep 12, 2015 2:21 pm
Cheers chaps, yes got lucky with the weather.
Rev limit is set at 7250rpm but I am holding it at around 7000 maximum in 4th at the end of the straight which is 110mph and easing off just past the start finish line, that is plenty lap after lap.
So lucky that oil was not on a fast section, dont know who the culprit was but at least four cars span onto the grass.
thanks again, roll on April/May for next visit
820Vitesse
Post by 820Vitesse » Sat Sep 12, 2015 2:22 pm
This was taken leaving the pit garage to go on track
mercedade
Post by mercedade » Sat Sep 12, 2015 3:44 pm
Wonderful picture!
rovercoup
Post by rovercoup » Sat Sep 12, 2015 5:58 pm
mercedade wrote:Wonderful picture!
Completely agree and nice to see an 800 that goes as well as she looks.
I do like the de-chromed look with the black and BRG
mjc9967
Post by mjc9967 » Sat Sep 12, 2015 6:53 pm
Looking a bit mint! Nice
Post by scoobyh123 » Sat Sep 12, 2015 7:42 pm
820Vitesse wrote:This was taken leaving the pit garage to go on track
Photoshop the Pugrot and those other two cars out of it and you'd have an awesome picture in its own right but also a fantastic "Brochure shot". Haven't watched your vids yet as t'internet is acting up (again!) thanks to the ground getting a good soaking recently.
Have to say the dechromed look on the rubbing strips and bumpers looks exceptionally good. I remember Ford did a similar idea in the 70s - the GT/S got black trim and the GXL/Ghia got chrome trim and it looked good then. You've taken a similar concept and improved it on the 800, well done! :D
rovercoup
Post by rovercoup » Sat Sep 12, 2015 8:07 pm
scoobyh123 wrote:Have to say the dechromed look on the rubbing strips and bumpers looks exceptionally good. I remember Ford did a similar idea in the 70s - the GT/S got black trim and the GXL/Ghia got chrome trim and it looked good then. You've taken a similar concept and improved it on the 800, well done! :D
The MK 1 Vitesse has all blacked out rubbing strips and bumpers. It may be that BRG, Stone Grey and similar colours make it work so well but it does give the car a more aggressive appearance, plus the lowering springs on that BRG car help.
Post by scoobyh123 » Sat Sep 12, 2015 10:07 pm
I hadn't noticed before Steve! Then again i've not seen many Mk1 Vitesses and would probably have thought it was an individual mod if i had noticed it. :oops:
820Vitesse
Post by 820Vitesse » Sun Sep 13, 2015 4:47 pm
Your comments are very appreciated thanks.
The dechromed rubbing strips is actually really simple, I used insulating tape to see how it would look, it fitted perfectly and lasted years before peeling. I got the idea from I hate to say it, BMW E39 M5.
The first video I have replaced, I have some film taken of the car in the pits and a brief clip caught me sliding through Graham Hill bend, I hadnt realized from inside the car the rear of the car was moving around so much.
cheers again
mjc9967
Post by mjc9967 » Tue Sep 15, 2015 10:08 pm
Still looks Nordic Blue to me (last picture above) :lol:
Post by scoobyh123 » Tue Sep 15, 2015 11:38 pm
Sometimes the simplest ideas are the best and why not rob BMWs for ideas? After all, they started it!!! :twisted: :lol: :lol: :lol:
820Vitesse
Post by 820Vitesse » Sat Dec 05, 2015 8:14 pm
Exactly Dave.
I have been a bit slow with the updates but here goes. The rear suspension is virtually standard other than cut down Spax road springs and as at the last trip to Brands Hatch the front grip and steering felt very good it was the back of the car that was lacking grip.
The front suspension is fitted with Black Powerflex bushes throughout, Leda uprated adjustable shock absorbers, 1600lb springs (probably over double the standard rate) increased camber due to lowering and sticky Dunlop race tyres.
Gaz have built me a pair of rear shock aborbers, they are one offs, based on the original shock but with a shorter body as the car runs a lot lower than standard, adjustable rebound with the adjuster at the top of the shock so it can be adjusted from inside the car and the body is threaded so I can convert to coilovers in the future and adjust spring rates.
This is the standard shock compared to the new Gaz shock
and the top adjuster
Initially I will fit just the shock with the Spax spring and see how well or not it works, then the plan is to convert fully to coilover and fine tune the spring rates and ride height.
I have posted a request for rear top mounts on here so they can be modified into a spring seat and top mount.
The rear ARB links will be replaced with Rose joint links to tighten the rear Sport 21mm bar up a little and the roll bar brackets and bushes will be replaced to.
Other jobs on the go are adding a footplate to the drivers footwell, adding crutch belts to the 4 point harnesses, cutting and moving the seat brackets, skimming the front brake discs, looking to see if the steering rack can be solid fixed to the subframe along with a few other tidying up jobs
I will try to make some progress this weekend and update in the week, thanks for looking
Post by scoobyh123 » Sat Dec 05, 2015 10:23 pm
Ah-ha! Where did you get the rear ARB bushes and do you have a part number/link please?
820Vitesse
Post by 820Vitesse » Sat Dec 05, 2015 10:25 pm
Just noticed my first post on this thread has gone! took me bloody ages to write that.
820Vitesse
Post by 820Vitesse » Sat Dec 05, 2015 10:30 pm
scoobyh123 wrote:Ah-ha! Where did you get the rear ARB bushes and do you have a part number/link please?
Here http://www.superflex.co.uk/products.php?cat=395 I fitted them today but because the new bracket is slightly wider than the original they foul the bend of the ARB slightly, I might need to make a small modification, I will get a picture tomorrow. so dont go ordering them yet
Users browsing this forum: No registered users and 27 guests
