Re: 1994 BRG Vitesse Fastback
Post by scoobyh123 » Mon May 10, 2021 3:08 pm
scotty2 wrote:
Mon May 10, 2021 2:11 pm
Epic! Fantastic work.
If you have any spare ABS sensors available, I may need some for TGMs next MOT. Please PM.
https://www.ebay.co.uk/itm/371033272993
That's a LH 2/400 sensor Scott but RH 800 sensor with a longer lead! :wink: :P
I believe they still have stock of the 2/400 RH so LH 800 - i bought a pair a few years back. You'll need to be rbutal to get the old sensors out of the brackets then slightly enlarge then mirror polish the bore of the brackets and smear silicone grease on the body of the new sensor to prevent the sensor being crushed again in the future.
If it's the back ones, they're a pig! Never done one on a ROver but done a few fronts on the Volvos i've had (same sensor but a different plug) and after the fun and games to get the old one out, again polished/enlarged the hole slight and plenty of silicone grease on the body of the sensor.
Post by Lodein » Mon May 10, 2021 5:27 pm
It is very beautiful
820Vitesse
Post by 820Vitesse » Tue May 11, 2021 2:39 pm
Thanks Scotty, no spare sensors unfortunately
Thanks Lodein, slowly getting there
820Vitesse
Post by 820Vitesse » Sun May 16, 2021 8:16 am
I wanted to change the steel bolts and washers that secure the front wings to the body with something different, 7 of the 8 came out fine but one of the captive nut clips broke and dropped into the inner wing box section when the bolt was removed, there is no way to get it out or fit a new one with the wing in place.
With the wing removed I can see the broken part and remove it with magnet
The car currently looks like this
For a 27 year old Rover with over 100,000 miles on the clock it is in really good condition.
I gave it a clean and vacuumed some greenery from a box section and it looks really sound
The front wing arch inner edge has some surface rust that needs treating and a couple of places where the wing bolts to the body but other than that it wont need much before it can go back together
820Vitesse
Post by 820Vitesse » Sat May 22, 2021 9:04 am
Couple of years ago I made a full size battery tray to sit in the rear footwell but for track days when the car is in "lightweight" mode I need to mount the 5kg Redtop battery, the previous mount wasnt suitable so bought a so called proper Redtop 20 battery holder.
For a item meant to be for this battery it needed some modification to work
and fitted
Post by scoobyh123 » Sat May 22, 2021 9:55 am
I might be imagining this Jim but the older Redtop batteries were taller (i think) so it's possible the battery holder you bought is for one of those.
Either way, a nice mod you've done! :wink: :D
Post by Marc-827-Vitesse » Mon Jul 19, 2021 5:33 am
Wow! Good to see it is as good as it looks! And great attention to detail there. Love it!
820Vitesse
Post by 820Vitesse » Mon Jul 19, 2021 12:38 pm
Thanks Marc. Work has slowed a little due to the hot weather and recent jobs not very interesting so updates are a bit slow. Removing more unused wiring from the front looms, re-making some old brackets. The plastic PAS resovior has been leaking very slightly for years so looking at a replacement. Then rubbing down some little rusty areas around the front end is all taking lots of time.
Post by scoobyh123 » Thu Aug 19, 2021 9:32 pm
That fits the RH front Scott, fairly sure they have RH front 2/400 sensors that will fit the LH front on the 800s. I bought a pair several years back and one is serving duty on my Sterling now.
820Vitesse
Post by 820Vitesse » Wed Sep 08, 2021 3:50 pm
Despite the car being in such great condition for its age there were a few rust spots around brackets and bolt holes in the front panels and bumper bar so these had to be repaired. This also led to more unused wiring removed from the front harness (450 grams!)
Then everything that is removed has to be cleaned up before refitting.
I cleaned and painted the bonnet catches a few years ago but they looked rough again after a couple of years so these were properly stripped, blasted and zinc plated with new springs this time.
original bonnet catches Image
painted catches Image
second attempt Image
Bumper brackets, wing fixings got the treatment too
Brackets before Image
brackets after Image
820Vitesse
Post by 820Vitesse » Wed Sep 08, 2021 4:01 pm
The door top seals that run up the A pillar along the roof and down the C pillars had probably never been off in 27 years.
Cleaned and ready to refit
Rust and paint on the font panel rubbed down, treated and primed
Brackets painted ready to refit and colour coded petrol cap.
Post by scoobyh123 » Wed Sep 08, 2021 4:49 pm
More excellent work there Jim! If you lose any more weight from the car, you'll be the heaviest thing in it! :wink: :P :lol:
820Vitesse
Post by 820Vitesse » Thu Sep 09, 2021 12:39 pm
Haha thanks Dave.
The front panel is painted
Parts starting to go back on. I opened up the apertures where the oil cooler hoses pass through to allow a bit more movement
Post by scoobyh123 » Thu Sep 09, 2021 1:00 pm
Nice to see plenty of channel grommet being used there Jim! :wink: :D
820Vitesse
Post by 820Vitesse » Fri Sep 10, 2021 7:09 pm
If its good enough for Rover its good enough for me.
The original plastic PAS reservoir developed a small leak years ago so bought a universal aluminium replacement, it is heavier than the standard tank but I made an aluminium mount to replace the steel mount to compensate.
The pipes come out the bottom rather than from the front of the standard tank so not a straight swap unfortunately
Users browsing this forum: No registered users and 32 guests
