1993 Rover 827 Si automatic
Post by Marc-827-Vitesse » Thu Aug 06, 2015 5:08 pm
Hi again :wink: ,
My father owns his mk2 827 Si sins 2008 and right after the purchase with 167 000 kms he brought it to the garage for major maintenance (because of that no pics of mechanical maintenance). I started the page on my father's 800 because i thought you fellow enthusiasts would like to be updated on his car as well :D .
Current millage is 204 000 kms.
Recent pics of the car after i treated the paint with clay to remove dirt and then wax polish. After a few hours my father was very grateful :D .
A few weak ago i noticed some spots on the rear sill's and started to poke in the body work to find some bodge jobs from a previous garage. Maybe fine for a short while but not good enough. The filler was expanding and therefor looking bad. Cleaned it very well with power tools and wire brush. After that i cleaned it and spray painted it with zink spray to prevent it from rusting further. In a few weeks it will be welded by me and a friend who has the good equipment. After that i will post new pics ;).
Left and right end of the sill near the rear wheels. After the zink spray i put some black to finish it for the moment and sealed it off with tape (very dodgy i know) to prevent water to come in.
The rest of the car was checked and is rust free. I will keep you posted :D .
Last edited by Marc-827-Vitesse on Sat May 12, 2018 5:29 pm, edited 2 times in total.
hotfuzz87
Re: 1993 Rover 827 Si automatic
Post by hotfuzz87 » Fri Aug 07, 2015 10:26 pm
you could still park that outside number 10 Downing street and it wouldn't look out of place
1987 Rover 820E white diamond
Previous 800's…
1998 Rover 820 Sterling fastback
1997 Rover 825 Sterling KV6 saloon BRG
1995 Rover 827i Nightfire
1991 Rover 820 Turbo 16v saloon Nightfire
1987 Rover 820 Si Shantung gold
hotfuzz87
Post by hotfuzz87 » Fri Aug 07, 2015 10:32 pm
reminds me of this promo pic
Previous 800's…
Captain Sensible
Post by Captain Sensible » Sat Aug 08, 2015 10:44 am
^^Looks identical to mine :D
Thanks for the pictures...Mine is going in the same place, but hopefully not as much metal will need to be replaced! What are the inner lips on the rear wings like?
Post by Marc-827-Vitesse » Sat Aug 08, 2015 1:04 pm
Hello Captain ;),
I presume you mean the wheel arch steel? I removed a lot of dirt of them and checked properly, a litle stone chip damage but no rust. Only place is the place on the pics. If i did not awnser the question please let me know and possibly i make pics for you.
All the best.
TDHFastback
Moderator
Post by TDHFastback » Sat Aug 08, 2015 1:05 pm
Black with cream interior. Lovely 8)
You've done a good job with the polishing there Mark
Kate :D
Post by Marc-827-Vitesse » Sat Aug 08, 2015 1:05 pm
Thanks Kate!!
Slamm
Post by Slamm » Sat Aug 08, 2015 7:35 pm
Without doubt the weak spot on 800's, mine were the same.
Nice job on the polishing. The only other black mk2's I've seen are the stretch limo's.
Mk2 Vitesse Fastback
Post by Marc-827-Vitesse » Sat Aug 08, 2015 10:09 pm
Haha maybe a good camera ;).
Good use of the soap is important in my opinion. I mean don't just touch every surface but really let the soap do its job because it will start the cleaning reaction after rubbing the soapy sponge a couple of times. You will remove more dirt and clean it better and reduce risk of scratching. After that Clay to remove residual dirt. The wax that i used was specific for dark cars and is made to remove/hide the oily/dull gloss on dark colored cars to give it the dark deep shine. Pics always make a car look better and if you look up close you will see some marks (no rust) but that is normal for and old car.
The last time is cleaned my Vitesse (washing, drying, clay clean, washing, drying wax on, wax of) took over 6 hours. So time is also an important factor when cleaning a car ;). I do panel for panel and keep going/re polish until satisfied.
Post by Marc-827-Vitesse » Sat Aug 15, 2015 4:03 pm
A few day's ago we noticed that the black beauty's alarm went of sometimes with no reason. Sometime ago i noticed that the car did not want to lock because there was still something not closed properly. The bonnet needed to be pressed again and then it would lock. But, as said the alarm would go of after a while. I went to the Facebook 800 page for advice and mr Simon Hubbard told me that the bonnet sensor is often the cause. I checked if it was still working and indeed it was, not locking when dismantled and when compressed it was. When i had a closer look to the sensor i noticed that the braked holding the rubber knob / sensor was bend down a bit. So the bonnet did not fully compressed the sensor / knob. After bending it back upwards it seems to have done the trick. The bonnet compresses the sensor telling the alarm all is well. Easy fix :D.
Post by Marc-827-Vitesse » Mon Aug 17, 2015 9:47 pm
Thanks for your reaction and indeed it is about my father's 827 ;)
Th car has been parked for a few days now and no alarm QE2 sounds from the garage :P ;).
If it goes again i would like to know which wires.
SJG
Post by SJG » Mon Aug 17, 2015 10:38 pm
Marc-827-Vitesse wrote:Thanks for your reaction and indeed it is about my father's 827 ;)
It is easy Marc, just follow the wires from the sensor and around 1/2 way along the headlamp under the slam panel you will find a little plug, just pull them apart.
SJG
Post by SJG » Tue Aug 18, 2015 9:17 pm
Oh thanks Paul I did not realise that.
Post by Marc-827-Vitesse » Wed Aug 19, 2015 9:44 am
Hi Simon,
Thanks again for your advice!
MRPCPC, thanks for the trouble you have put in to check the manuals. I will try to find your connection as well.
(great to have a forum like this were people do everything they can to help out, thanks).
traineefarmer
Post by traineefarmer » Wed Aug 19, 2015 12:22 pm
Sadly, mrpcpc will no longer be able to offer his knowledge to members.
