Manalishis red Vitesse Sport
Re: Manalishis red Vitesse Sport
Post by Manalishi » Fri Nov 24, 2017 2:27 pm
Austin Seven Ruby -36
Rover 216 coupe -93
Post by scoobyh123 » Fri Nov 24, 2017 4:20 pm
They look grey to me Dean and i seem to recall when i looked on Rimmers they only have them in LHD - you won your bet!
Think i had the last set of Stone Beige "Premium" RHD mats from Rimmers in a sale a few years back for the princely sum of £18 delivered.
Given that Rimmers are in the UK with RHD being the predominant one and allbrit.de are in Germany where it's predominantly LHD, you may be lucky and find some RHD mats there :
http://allbrit.de/UNI.cfm?PAGE=734027&SPRACHE=EN
Can't guarantee they will have a sale on, even though it's Schwarze Freitag! (Black Friday) :wink: :D
Post by Manalishi » Sun Nov 26, 2017 12:27 pm
Dash glued. New mats in place. Mm!
Rover 216 coupe -93
Post by scoobyh123 » Sun Nov 26, 2017 12:59 pm
Getting there Henrik! :D
Seems odd seeing the interior of an 800 with the steering wheel on the "wrong" side but i suppose ours must look odd to you as well. :wink: :D
Post by Manalishi » Thu Nov 30, 2017 1:52 pm
Ok a small update with som questions for the gurus.
First pic. The front doors dont align as seen. Is it fairly simple to unbolt the hinges and give it a try or will I get into more trouble?
Second pic. My very good friend Gunnar stopped by yesterday with some nice wood for the centre console. Looks great! The gear gaiter is from eBay, excellent fit and quality except for the inside moulded ring under the knob. But I’ll sort that later.
Third pic. Roof, behind rear door. I guess there should be some trim here? I suspect it was something black, plastic removed to sort the progressing rust.
Still a great runner. Feels so small compared to my coupe which is strange as the recaros actually are both lower and further back. This feels more like my old 620ti did! Love it!
Rover 216 coupe -93
Post by scoobyh123 » Thu Nov 30, 2017 5:40 pm
First pic Henrik - it looks like you'll need to adjust the door a little - if you look closely at the hinges and the doors where they mount, there are alignment marks stamped into the doors, body and the hinges. Check those first to see if they are out of alignment, looking at the door it looks as if someone has forced the door open at the top to drop some string or similar down to lift the lock button.
Second pic - looking good! Vast improvement! :D
Third pic - allowing for weathering of the paintwork, that's how it left the factory. They run a bead of "seam sealer" into the gap and then paint over it, my Sterling saloon is the same and all other saloons i've seen have been the same, including both my Mk1s.
Perhaps because the Vitesse suspension is 20mm lower and the Recaros make you sit lower that is why it feels smaller?
Post by Manalishi » Thu Nov 30, 2017 8:23 pm
Thanks Dave, didnt know the alignment marks existed. Will check tomorrow! I think the Doors are misaligned as the top of the door side isn’t inline with the wing. Not an extreme issue but passing 65-70mph means loads of hissing noise from the A-pillar and top frame.
Regarding the seats I must say the sterling interior is a LOT thicker and higher. I’m 188cm and the coup is a tad too small!
The suspension is rock hard on this one. Driving known roads really tells the difference. My coup has the normal Vitesse springs but thicker ARBs. This is a lot stiffer, and this is on 15inch wheels!
Oh, and sorry for strangely used capitals. My phone thinks Im writing in Swedish! :D
Rover 216 coupe -93
SJG
Post by SJG » Thu Nov 30, 2017 8:27 pm
Hey Henrik, good to see you enjoying this little beast. Really enjoying the thread.
Post by Manalishi » Thu Nov 30, 2017 8:57 pm
Thanks Simon!
Less than 10 820ti/Vitesse sport left over here. These Rovers from the Honda collaboration always were severely underrated both in performance and durability. I love it!
Rover 216 coupe -93
Post by Manalishi » Fri Dec 01, 2017 9:31 am
Adjusting the hinges were easy peasy and Done in 5 minutes. I couldnt find any alignment marks on the front hinges but the rear one fitted with two large torx had marks. Adjusted front an rear and door is now flush with the rest of the body.
Rover 216 coupe -93
Post by scoobyh123 » Fri Dec 01, 2017 9:57 am
Excellent news Henrik! Must be a lot quieter inside now! :wink: :D
Post by Manalishi » Fri Dec 01, 2017 10:39 am
Just about to take it for a spin on the motorway but feel pretty confident it Will Dave!
Just need to sort those door cappings now. ;)
Rover 216 coupe -93
Post by scoobyh123 » Fri Dec 01, 2017 12:26 pm
According to the Post Office, you should have them in 3 working days Henrik! Just back from posting them! :wink: :D
Post by Manalishi » Fri Dec 01, 2017 12:45 pm
Wohoo! :D
And yes, the car is dead quiet now. Even did a short burst at a bit higher speed and no noise around the doors.
So, next step is my boot lid. Misaligned aswell. Either this car has been put together by inhabitants of a local zoo, or it's been smashed up various times and then reassembled by - yep: inhabitants of a local zoo! :D
After that a somewhat sticking throttle cable. When cold, not an issue, when hot sticking in the upper position/idle making driving in slow traffic a bit annoying, Have been feeling the spindle and it's not sticking, lubricated the pedal and the wire itself, but probably the lubricant can't reach into the bowden cable. Probably need to lift the cable off the car.
Rover 216 coupe -93
Post by scoobyh123 » Fri Dec 01, 2017 1:03 pm
When you say the bootlid is misaligned, which way do you mean? The side to side adjustment is under the parcel shelf trim, one each side.
The rest of the adjustment can be found fairly easily - hinge to bootlid, striker and of course the rubber buffers near the top of the light clusters on the body.
I don't think you have a sticking throttle, more like the stepper motor for increasing the idle speed when cold and also when hot if the air-con is running for example or if the battery is in a low state of charge or its last legs.
Are there any clues the battery might be low or on its way out? Things like having to frequently reprogram the windows, losing the radio code, windows all opening when you start and other oddball things?
Sometimes these won't show up immediately but substituting a known good battery should sort things out.
Also if the battery has recently been changed or went flat, it's possible that MEMS is relearning everything and the idle speed will drop with use - also worth checking the rubber throttle body mount for air leaks as a leak here will increase the idle speed and cause a bit of rough running. Also the CTS (Coolant Temperature Sensor) not to be confused with the temperature gauge sender although i think both are in the thermostat housing. Long time since i was "hands on" with a T-Series but hopefully someone else can confirm the location of the CTS.
They usually fail in a state that tells the MEMS the engine is cold so the idle speed remains high and it throws extra fuel in for cold start enrichment permanently. :shock: Check the coolant level too, if that's low it can give the same symptoms.
A few things there to keep you busy! :wink: :D
