Thanks for the offer, I might get back later on.Nuts4my827 wrote:Yes, it's a covered board that goes behind the back seat. The Boot mat should be the same as the Saloon in shape. What you are also missing is the little triangular pieces of Carpet that go behind the centre console....
Do you want some? I have them you can have. PM Me your address etc...
Manalishis 820 Vitesse Coupe
- Lord Sterling
Now boys, calm down. We don't want this to escalate into a fist-fight.Lord Sterling wrote:There is if you dont like them, which I dontRichard Moss wrote:...there's no reason to remove them...
Lord Sterling
I've been away for a few days on midsummer holiday, a Swedish tradition involving large quantities of alcohol, food and singing. However before I went I washed my boot thoroughly as there was a small smell of mould. Apparently water is getting in or used to. It is totally dry even after a recent heavy rain so the problem might be solved but I think I've read that the rear light seals can be bad, just like with the smaller 200 Coupe.
- Lord Sterling
Easy to rip 'em out (Hacksaw ) Though a good idea if you've got a Coupe.Rusko wrote:...I'll seal the smoked lights when I put them on. (Sorry Lord Sterling )...
The boot leakage problem is common amongst Coupes and the area mostly pointed at are the lights which were either not sealed properly by Rover or the sealent has perished over time hence the boot leakage.
If no water has collected after a downpour then looks like it been sorted, though do be aware that water can collect and trap itself in the soundproofing under the carpet, if you ever have to take your seats for any reason take a peek under the carpet to make sure its not damp.
Lord Sterling
Sorted...Lord Sterling wrote: ...take a peek under the carpet to make sure its not damp.
Lord Sterling
I ripped out everything on Thursday and washed the floor, spare wheel tray etc rigorously with detergent and shampoo. I just went out and had a smell and it is all gone now. Hopefully it will be nice cruising weather tomorrow so I can take a few snapshots of the Swedish country side.
Today I took a gigantic leap into the 21th century. I swapped the very, very old broken cassette player:
The sound is actually better! Now I just need to tidy up a few wires. Unfortunately the front speakers were missing, so I replaced them aswell.
Still a few things to do. I need to pay some attention to my sills and also the rear bumper needs some paint, the gold part.
Simon Hubbard wrote:I think there is a hardboard panel and piece of carpet, i say i think, i can look tomorrow at mine and take a picture.
First of all apologies for taking so long to get back to you, i missed the message. Anyhow here are some pictures of the panel in the boot - it is a hardboard piece covered in carpet.Yes please do. I'm interested in how it should look as I'm trying to get back to original.
Simon, I spotted your car earlier and it looks absolutely gorgeous! Did you colour-code the front lower bumper part? The car looks very modern and more aggresive with it painted. I think I will be doing that aswell.
Held on with 2 of these:
The colour coded front bumper was like it when i got the car, i think it had had a prang and had a replacement bumper fitted - which was not sprayed properly.
I am going to respray the bumper so it has the original black section as the rest of the car is correctly coloured. This is part of my on-going "rolling restoration".
Hope the mid-summer celebrations were good this year, i remember them well - actually i dont remember too much about them when i was in Sweden.[/quote]
- Location: Wantage/Chippenham [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Actually from 1992 to 1996 the made over 3 times as many turbo coupés s 827i coupes, but they are almost all LHD, as italy bought 3/4 of coupé roduction and thier tax system makes anything over 2 litres almost unsalable!ken6760 wrote:Looks like a rare beast!! Never seen or heard of one like that in the UK.
I always thought the Vitty Coupes were introduced in 1996 with the 197bhp wasted spark unit!!
Nice car btw!!
1997 Citroen XM TCT VSX
1985 VW Golf GTI
1975 MG Midget
1985 VW Golf GTI
1975 MG Midget
- Kyle
Hi Malanishi, there is also another place you should check for leaks on your coupe - If you look around where the drain channel is around the boot, on both sides you should see a join in between the panels, here the sealant can come away and water can leak in that way.
