Manalishis 820 Vitesse Coupe
Thanks Dave, I’ll report back after the test.
Looking forward to it Henrik!
Yes! Approved today and the tester was even impressed by the state and quality. So Now it’s taxfree and only need a testing every second year so next Time in 2025!
The balancing between the front brakes were a bit off But still within the limits. Probably due to standing for 6 months.
A fun detail is it being a Range Rover!
Congrats on the pass Henrik!
Quite annoying. My old, but new battery is dead. I’ve had it on one of those low power charger (probably a better Word for it…) during winter and it came to Life perfectly as I took it out from the garage But now it’s dead not accepting charging. Gave it a try in the 827 to rule out any errors in the coupe But same there.
Really annoyed as the battery was new last year and batteries aren’t free. I Might be wrong though this being an older battery But I don’t think so.
Anyway. Battery scrapped now and new in place. So everything is perfect but my Wallet is thinner…
This weekend we’re doing oil and filter change for both Rovers.
They don't make batteries like they used to Henrik! I had one die in similar circumstances, not happy about that as it was only 18 months old.
Hope your new one lasts considerbaly longer!
Thanks Dave. Yes I agree. It used to be better!
You hear this more often nowadays. Quality of batteries is going down.
Good luck with the oil change!
Good to hear you're out enjoying your Coupe Henrik! An oil/filter change always makes things nicer too!
Yes it feels somewhat safer knowing the fluids are fresh. I really enjoy it, last season was really useless with More or less no driving at all.
It still makes a strange noise When pulling away and the Clutch needs more bleeding But overall it drives very Well. On the plus side, the tester couldn’t find anything so I just drive it more gently. New droplinks and a new tie rod. Very tight and Nice.
The turbo wont give more than 0.6 bar But it doesn’t matter. It’s still quite ok, and not too far off the original boost for the 180bhp vitesse. I think the spring in the wastegate actuator is weak and wont hold the boost. But I don’t know.
There's something about an 800 and driving it that just makes you feel good!
A small update on my boost.
It seems my electronic Gizzmo boost controller was faulty and it only gave "factory boost". Not sure why but as it's electronic it's not much to do really. So I disconnected the vacuum from the wastegate and reinstalled the original boost controller, BMV. A nice detail is that the Gizzmo boost gauge still is attached in the line so I can see the boost increase.
Another nice discovery is that it apparently was the BMV-valve from my 620ti so it's now a 200bhp Coupe and not an 180bhp coupe. Ok, I admit I liked the electronic controller as it was very stable and had 6 presets, but this is equally good.
Great news Henrik!
Thanks Dave. Small things But We like it!
